Viewing Zoneminder from a Blackberry?
is it possible to get a low bandwidth stream which can be viewed on
my Blackberry 8700?
Mike
my Blackberry 8700?
Mike
I have the exact same phone/thing. Have not been able to login using the browser as yet, it seems to just hang after the login, without bringing up the console screen.
The phone apparently does support java, and have not had a problem viewing my other sites on it (gallery2 php site for the grandparents to view).
http://www.brighthand.com/default.asp?newsID=12268
Any suggestions would be GREATLY appreciated!
Sweet, that works on my iphone. Previously I had to turn off DVR functions to get it to work. Hadn't really tested it that much, has been low on my priority list.
kingofkya wrote:if you just want mobile access it works fine with
If you open the mobile page http:/example.com/zm/index.php?format=xhtml
Started a wiki page for mobile devices
http://www.zoneminder.com/wiki/index.php/MobileDevices
add your phone model(s)
server time out on blackberry internet browser
novausc, can you see the login page using blackberry internet browser?because mine is always giving me "server time out" error message.
thanks.
thanks.
blackberry
Yes, I'm not having any issues with getting to the login page at all.
blackberry
I'm having the same empty boxes with index.php?skin=mobile on blackberry
What needs to be changed in configuration?
Same problem with me on the iphone 3G S
If I visit http://myurl.com/zm/index.php?skin=mobile
I can login and see the links to the monitors, but then it's just an empty box with a little question mark graphic, and no image or stream.
I'm running the latest larch CD install.
Here is what it looks like:
-Brian
-Brian
