Character replace
If you would like to check the status of a language, volunteer to do a translation, or highlight or correct a problem in one of the existing language files then post here.
oddo
Character replace
Post by oddo »
Hi
there is a problem in the "Options" page in Romanian language
there are special characters that are not correctly rendered:
one example:
character ă -
& # 2 5 9 ; (- the correct code without the spaces)
I put the spaces because this page replace the code with the right character.
what is wrong:
the "options" page replace
with
so the code became
& a m p ; # 2 5 9 ; (- the wrong code without the spaces)
and the text rederend by the page looks like this:
Limba implicită
the code is:
Limba implicită
and it sould be
Limba implicită
the wright code is:
Limba implicit & # 2 5 9 ; (- the correct code without the spaces)
how can i fix this?
thanks
miwa
Post by miwa »
