'perl zmconfig.pl' gives an error
swat
Post by swat »
I finally came to a point where I installed all needed files (including devMySQL and devJPEG etc.) then I finally could compile/install zoneminder.
I configured it with: "./configure --with-mysql=/usr/local/mysql-standard-4.1.0-alpha-pc-linux-i686/ --with-webdir=/var/www/html --with-cgidir=/var/www/cgi-bin"
Then I wanted to configure it with "perl zmconfig.pl" but it gave this error:
"Can't locate DBI.pm in @INC (@INC contains: /usr/local/lib/perl5/5.8.1/i686-linux /usr/local/lib/perl5/5.8.1 /usr/local/lib/perl5/site_perl/5.8.1/i686-linux /usr/local/lib/perl5/site_perl/5.8.1 /usr/local/lib/perl5/site_perl .) at zmconfig.pl line 31.
BEGIN failed--compilation aborted at zmconfig.pl line 31."
HELP?
laps
Re: 'perl zmconfig.pl' gives an error
Post by laps »
Maybe you need the mysql perl library. I Installed mine from the RH9 cd #2 , it was called perl-DBD-Mysql-????????.rpm . I hope this helps.
swat
Post by swat »
Hmm... I'll try it (I'll download it from mysql.com)
I'll get back to it in a week or so (I'm going on vacation)
zoneminder
Site Admin
Post by zoneminder »
Hi Sebastian,
I would recommend using the perl CPAN module to install perl modules. This is described in the README (search for CPAN). The modules you should try and install are DBI and DBD::mysql
Cheers,
Phil,
