thanks cordel. let me take it one step at a time...
1. I am using 3 cameras. I have only 3 inputs configured, all 3 running at 320x240,rgb24,3 fps.
2. everything was running ok as default
(ie. Image Buffer Size (frames) 40
Warmup Frames 25
Pre Event Image Count 10
Post Event Image Count 10
Stream Replay Image Buffer 1000
Alarm Frame Count 1) until the image started ''flickering''. that's when i stepped in and changed the settings from above to half (ie. image buffer size 20,warmup frames 12,pre event image count 5,post event image count 5 and stream replay image buffer 500). these settings worked, for a while, and now, the image is back at doing what it knows (:) flicker) and if i try to change the buffers back to the default settings, all monitors in zm console turn red.
ipcs -l comes back as :
------ Shared Memory Limits --------
max number of segments = 4096
max seg size (kbytes) = 4194303
max total shared memory (kbytes) = 8192000
min seg size (bytes) = 1
------ Semaphore Limits --------
max number of arrays = 1024
max semaphores per array = 250
max semaphores system wide = 256000
max ops per semop call = 32
semaphore max value = 32767
------ Messages: Limits --------
max queues system wide = 16
max size of message (bytes) = 65536
default max size of queue (bytes) = 65536
3. and 4. haven't thought of doing, but once i get home i'll try it and let you know what happens.
Thanks again for taking the time to bother with such issues...
