xlib_shm / xlib_raw viewer question
50cc
Post by 50cc »
I installed xlib_shm on our server, it's great!
At the moment I run it by clicking a shortcut I made in the XFCE window manager which runs this:
sudo ./xlib_shm -m 1 -m 23 -m 11 -m 12 -k 0x7a6d0000
Apparently I need to be root to run it so I need to sudo it and enter the root password.
I would like to start xlib_shm automatically when XFCE starts without the sudo/root problem.
How would one accomplish this??
rdmelin
Post by rdmelin »
Make xlib_shm setuid root.
sudo chown root.root xlib_shm
sudo chmod +s xlib_shm
Then you can run it without using sudo.
I dont' use XFCE but I think it uses ~/.config/autostart or similar to run programs at startup. Google will help you with that.
50cc
Post by 50cc »
Many thanks! It worked! :D
I posted the 'entire' story on my new blog:
http://selfmadenetadmin.blogspot.com/20 ... start.html
johnnytolengo
Post by johnnytolengo »
I don't have xlib_shm in my PC.
how to install it?
I can't find the package with: aptitude search xlib_shm
thank you.
J.
50cc
Post by 50cc »
Quote from my blog on setting this up:
Here's how I got it to work (once you know how it's really simpel):
Downloaded this file:
wget http://dig.hopto.org/xlib_shm/xlib_shm-0.6.3.tgz (the one without OpenGL for this older embedded intel card)
Installed Xvideo dev files:
sudo apt-get install libxv-dev
sudo nano xlib_shm.c
And changed /usr/local/etc/zm.conf into /etc/zm/zm.conf
sudo make all
Place the binary xlib_shm in /usr/sbin/
Ran the new binary with four monitors and the shared memory ID used by our Zoneminder installation.
It worked! Excellent!!!
More info on extra scripts, options and automation are on my blog.
