Hello I need some help.
I have installed zone minder but can not access the video feed. The below is the output of the log. I am running this on unbuntu 8.10.
Thank you for you help
Dec 16 16:25:16 FRCCDVR01 zmwatch[4896]: INF [Restarting capture daemon for PCIroom, shared memory not valid]
Dec 16 16:25:16 FRCCDVR01 zmdc[4863]: INF ['zmc -d /dev/video1' starting at 08/12/16 16:25:16, pid = 6961]
Dec 16 16:25:16 FRCCDVR01 zmwatch[4896]: INF ['zmc -d /dev/video1' starting at 08/12/16 16:25:16, pid = 6961]
Dec 16 16:25:16 FRCCDVR01 zmdc[6961]: INF ['zmc -d /dev/video1' started at 08/12/16 16:25:16]
Dec 16 16:25:16 FRCCDVR01 zmc_dvideo1[6961]: INF [Debug Level = 0, Debug Log = <none>]
Dec 16 16:25:16 FRCCDVR01 zmc_dvideo1[6961]: ERR [Failed to open video device /dev/video1: Permission denied]
Dec 16 16:25:16 FRCCDVR01 zmdc[4863]: ERR ['zmc -d /dev/video1' exited abnormally, exit status 255]
Erro can not access video devices
Re: Erro can not access video devices
You have two problems...the biggest: Failed to open video device /dev/video1: Permission deniedbvinsonj wrote:Hello I need some help.
Fix:
chmod 777 /dev/video1 and / or zmfix -a
Second...you need to look at the WIKI for shared memory and how to fix the error.
I am having problem with this too, but I'm getting a different error.
I have two monitors configured: one local and other remote (id 2 - http://64.122.208.241:8000/axis-cgi/mjp ... era=&resol). Configuration of the remote monitor:
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: 64.122.208.241
Remote Host Port: 8080
Remote Host Path: http://64.122.208.241:8000/axis-cgi/mjp ... era=&resol
Remote Host Subpath: --
Capture Width: 320
Capture Height: 240
zmdc.log
12/17/2008 14:39:33.016891 zmdc[11761].INF [Starting pending process, zmc -d /dev/video0]
12/17/2008 14:39:33.019591 zmdc[11761].INF ['zmc -d /dev/video0' starting at 08/12/17 14:39:33, pid = 11969]
12/17/2008 14:39:33.910150 zmdc[11761].ERR ['zmc -d /dev/video0' exited abnormally, exit status 11]
12/17/2008 14:40:35.166656 zmdc[11761].INF ['zmc -m 2' exited normally]
12/17/2008 14:40:40.066907 zmdc[11761].INF [Starting pending process, zmc -m 2]
12/17/2008 14:40:40.072490 zmdc[11761].INF ['zmc -m 2' starting at 08/12/17 14:40:40, pid = 12000]
12/17/2008 14:43:49.111939 zmdc[11761].INF ['zmc -m 2' exited normally]
zmwatch.log
12/17/2008 15:04:58.446515 zmwatch[11806].ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
12/17/2008 15:05:08.448638 zmwatch[11806].ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
12/17/2008 15:05:18.450464 zmwatch[11806].ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
12/17/2008 15:05:28.452404 zmwatch[11806].ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
12/17/2008 15:05:38.454073 zmwatch[11806].ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
12/17/2008 15:05:48.455588 zmwatch[11806].ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
12/17/2008 15:05:58.457446 zmwatch[11806].ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
12/17/2008 15:06:08.459607 zmwatch[11806].ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
12/17/2008 15:06:18.461697 zmwatch[11806].ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
/var/log/messages
Dec 17 15:44:53 liviab zmdc[11761]: INF [Starting pending process, zmc -d /dev/video0]
Dec 17 15:44:53 liviab zmdc[11761]: INF ['zmc -d /dev/video0' starting at 08/12/17 15:44:53, pid = 12537]
Dec 17 15:44:53 liviab zmdc[12537]: INF ['zmc -d /dev/video0' started at 08/12/17 15:44:53]
Dec 17 15:44:53 liviab zmc_dvideo0[12537]: INF [Debug Level = 0, Debug Log = <none>]
Dec 17 15:44:53 liviab zmc_dvideo0[12537]: INF [Starting Capture]
Dec 17 15:44:53 liviab zmc_dvideo0[12537]: INF [Got signal 11 (Segmentation fault), crashing]
Dec 17 15:44:53 liviab zmc_dvideo0[12537]: ERR [Signal address is 0xb7f9f002, from 0x806319e]
Dec 17 15:44:53 liviab zmc_dvideo0[12537]: ERR [Backtrace: /usr/local/bin/zmc [0x806319e]]
Dec 17 15:44:53 liviab zmc_dvideo0[12537]: ERR [Backtrace: /usr/local/bin/zmc [0x806b6ca]]
Dec 17 15:44:53 liviab zmc_dvideo0[12537]: ERR [Backtrace: /usr/local/bin/zmc [0x804cc10]]
Dec 17 15:44:53 liviab zmc_dvideo0[12537]: ERR [Backtrace: /lib/libc.so.6(__libc_start_main+0xe6) [0x2e05d6]]
Dec 17 15:44:53 liviab zmc_dvideo0[12537]: ERR [Backtrace: /usr/local/bin/zmc(__gxx_personality_v0+0x3a5) [0x804c401]]
Dec 17 15:44:53 liviab zmc_dvideo0[12537]: INF [Backtrace complete]
Dec 17 15:44:53 liviab zmdc[11761]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 11]
Dec 17 15:44:58 liviab zmwatch[11806]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 17 15:45:08 liviab zmwatch[11806]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 17 15:45:18 liviab zmwatch[11806]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
What means 'exit status 11'?
And, although the message "'zmc -m 2' exited normally", the ZM is not showing any image. It is completly black.
Capture Width: 320
Capture Height: 240
zmdc.log
zmwatch.log
/var/log/messages
Problem with video devices
Cordel, thanks for your reply!!
But, it didn't work...
I think it is a problem about shared memory but I don't know what I can do to fix it.
Now the ZM has only the remote monitor. See what the file /var/log/messages says:
Dec 18 12:19:22 liviab zmdc[3303]: INF [Starting pending process, zmc -m 2]
Dec 18 12:19:22 liviab zmdc[3303]: INF ['zmc -m 2' starting at 08/12/18 12:19:22, pid = 3598]
Dec 18 12:19:22 liviab zmdc[3598]: INF ['zmc -m 2' started at 08/12/18 12:19:22]
Dec 18 12:19:22 liviab zmc_m2[3598]: INF [Debug Level = 0, Debug Log = <none>]
Dec 18 12:19:22 liviab zmc_m2[3598]: INF [Starting Capture]
Dec 18 12:22:31 liviab zmc_m2[3598]: ERR [Can't connect to remote camera: Connection timed out]
Dec 18 12:22:31 liviab zmc_m2[3598]: ERR [Unable to connect to camera]
Dec 18 12:22:31 liviab zmc_m2[3598]: ERR [Failed to pre-capture monitor 0]
Dec 18 12:22:31 liviab zmdc[3303]: INF ['zmc -m 2' exited normally]
Dec 18 12:22:36 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:22:46 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:22:56 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:23:06 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:23:16 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:23:26 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:23:36 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:23:46 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:23:56 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:24:06 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:24:16 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:24:26 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:24:36 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:24:46 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:24:56 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:25:06 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:25:16 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:25:26 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:25:36 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:25:46 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:25:56 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:26:06 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:26:16 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:26:26 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:26:36 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:26:46 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:26:56 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:27:06 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:27:16 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:27:26 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:27:36 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:27:46 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:27:56 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:28:06 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:28:16 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:28:26 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:28:36 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:28:46 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:28:56 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:29:06 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:29:16 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:29:26 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:29:36 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:29:46 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:29:56 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:30:06 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:30:16 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:30:26 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:30:36 liviab zmwatch[3340]: ERR [Can't get shared memory id '7a6d0002', 2: No such file or directory]
Dec 18 12:30:36 liviab zms[3634]: INF [Debug Level = 0, Debug Log = <none>]
Dec 18 12:30:36 liviab zms[3634]: WAR [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
Dec 18 12:30:36 liviab zms[3634]: WAR [Unable to store frame as shared memory invalid]
Dec 18 12:30:49 liviab zms[3645]: INF [Debug Level = 0, Debug Log = <none>]
Dec 18 12:30:49 liviab zms[3645]: WAR [Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results]
Dec 18 12:30:49 liviab zms[3645]: WAR [Unable to store frame as shared memory invalid]
Do you know something about this problem?
