Hello, I'm trying to use the zm4ms, zmviewer and oter to get a stream of my remote zm server, but I can't gei the to work. They ask me for a username and password, I had tried every password I have, varios zm users, zm admin, mysql root, but no one works, I always get "acces denied to DREMA@remoteserver.org".
Hi, thanks for your reply, I tried every user and password I have with no luck, I also commented out the line "bind network access only to: localhost", but I still can't connect.
Also tried de jzmc, but it doesnt accept my user/pass.
Any suggestion?
Hi Caladeira, thanks for your help!
Locally I can conect to the mysql server with no problem, but when I try to "mysql -h my mysqlserver.com -u root -p" I got "ERROR 1130 (00000): Host '189.xxx.xxx.xxx' is not allowed to connect to this MySQL server" so its clear for me that i cant get remote/localnetwork connection on this server, so how do I enable connections to my server?
I repeat, I'm using Ubuntu Intrepid32.
I think you should look your firewall settings and mysql configuration files.
You mention Ubuntu Intrepid, but which version Server or Desktop?
Some people use desktop versions for server work because of a more user friendly interface.
I think firewall have different settings where you are using Ubuntu Server or Desktop.
Hopefully, some mysql expert read this post and post some solution.
GRANT ALL on $_zm_database_name.* to $_your_username@'%' identified by '$_password';
Replace $_ with your real data.
The symbol % gives the user access from anywhere only on zm mysql database. If you have a static outside ip or a subnet you could also use it.
