Anyone else having problems with the cycle view? I'm assuming it's suppose to cycle through the different feed's available. I have 3 cams up and running an the montage view works, but the cycle view just sits on the first cam's image. Maybe I missed something, but I've tried it with Firefox and IE7.
Zoneminder 1.24, newest one installed with ffmpeg compiled from source as per directions.
Cycle view not working
Re: Cycle view not working
It's working fine for me. Have you checked the cycle time(s)?foxtroop11 wrote:Anyone else having problems with the cycle view?
I thought man if that's all it is I'd feel pretty stupid. I changed it from 30 seconds down to 15 and a bunch of other times, still stuck on the first feed that comes up and stays there. Not sure what went wrong.
update: I just found out if I change it to stills it does cycle through the feeds, and then if I click it back to stream it also cycle's through. Did you have to do the same or did it just work right after you clicked the cycle button?
