Detected 2394.485 MHz processor.
Console: colour dummy device 80x25
Calibrating delay loop... 4784.12 BogoMIPS
bash-2.05b# uptime
11:16:54 up 10 min, 2 users, load average: 0.27, 0.18, 0.09
39 processes: 38 sleeping, 1 running, 0 zombie, 0 stopped
CPU states: 11.5% user 1.7% system 0.0% nice 0.0% iowait 86.7% idle
Mem: 512956k av, 125516k used, 387440k free, 0k shrd, 12260k buff
16988k active, 96988k inactive
Swap: 996020k av, 0k used, 996020k free 58328k cached
NOTE:
i haven't yet killed all the useless proccess nor have i loaded zm. System currently running
apache .31 and mysql, ftp, sendmail, pop,
Question:
with 512 ram (DDR400) (upgradable if needed)
2+ghz intel ( can change to amd if need be)
160gb hd,
Is it possible to run 16+ cameras off this system or whats the limit for system.
im looking on running a Medium preformance video at 320x*,
if someone could give me a heads up would be apreciated,
i have recompiled the kernel to optimize the cpu architek.... so
System Preformance vs Camera Amounts?
My experience suggests your machine should be adequate. You probably want to keep an eye on shared memory, depending on what else your host is doing. The snapshot you provided indicates it's a pretty idle host!
Have a look at the readme doc to calculate shared memory usage, which is basically dependent on image size, depth and number of cameras.
My machine is a P3 500, 256mb memory with 6 cameras. Loadave generally sits about 0.8, little or no swapping. I'm happy with the performance of this machine.
The only thing I notice is when apache is running hard the load ave increases dramatically... I've made the decision to move all non-zoneminder stuff off this machine - I don't want to compromise Zoneminder's ability to capture events simply because someone else is hitting my web server!
