Did anyone ever get a Pico card working?
t00t
Post by t00t »
I've just started playing with Zone Minder, and was wondering if anyone had managed to get it to work with a Pico Card, I have 1 channel up and running with the card type set to 13, but I don't get any additional channels in the dev/v4l/ directory.
I'm assuming the card I have is Pico, but as it's a cloan card it's hard to be sure :wink:
The model number on it is WL-020204A
Thanks in advance
whiteowl
Euresys Picolo Tetra - did not work with regular bttv driver
Post by whiteowl »
I have a 1-U server with a PCI-X slot and 3.3 v signalling. I tried the Euresys Picolo Tetra (not the Tetra-X) and it did not work. The bttv driver did detect the board and the 4 video devices were set up. But I would only get a black screen. I speculate that the Tetra has 64 bit transfers and the driver is only set up for 64 bit drivers. Now if the Picolo 2 would work in a regular PCI slot with the BTTV drivers is another question which I cannot answer.
t00t
Post by t00t »
actually I was talking about the Pico card not the Picolo.
However I did eventually get it to work with the following V4L settings.
CardType 104
gbuffers 4
tuner 4
although the frame rate was so bad I've decided not to use Zoneminder/V4L
CreativeBR
Post by CreativeBR »
t00t wrote:actually I was talking about the Pico card not the Picolo.
CardType 104
gbuffers 4
tuner 4
Dear t00t,
Did you find any other solution to use pico cards under linux ?
Thanks.
()s
CreativeBR
fernando
Post by fernando »
what linux/release/kernel. are all using?
i use mdk 10.1 and all is going well that card is a simple bt878 chip.. nothing magical or strange.
Fernando
t00t
Post by t00t »
Sorry CreativeBR,
I've not really played around with it anymore, perhaps there are some native drivers somewhere, although I've never been able to track any down.
t00t
CreativeBR
fernando wrote:what linux/release/kernel. are all using?
Hi Fernando,
I[m trying to install the liveCD and set up a system with 2 bt878a cards (pico2000 i think).
Could you tell more about the frame rate that you got in your system?
Using WinXP, generic WDM drivers and ActiveWebCAM 5.0 i could get this frame rates:
1 Pico 1 camera input - 25 FPS
1 Pico 2 camera input - 5 FPS
1 Pico 3 camera input - 3 FPS
2 Pico 2 camera input (one input per card) - 18 FPS for both cards
2 Pico 3 camera input (2 cameras to one card- 1 camera to the other) - 18 FPS and 3.5 FPS
So i think under linux may be i could get a better performance than this.
CreativeBR
