filters and audit
tommy
filters and audit
Post by tommy »
I've set up a filter to delete the latest event from a particular camera when my disk usage hits 95%. It seems that the audit job only runs every 900 seconds. This means that although I have deleted an event, my disk usage may remain at 95% for up to 15 minutes. In the meantime, the filter may flag yet another event for delettion since the disk usage is still at 95%. Am I not losing events unnecessarily?
I've tried unchecking the fast delete option but it doesn't seem to make a difference.
zoneminder
Site Admin
Post by zoneminder »
You can reduce the zmaudit delay. It is passed into zmaudit from zmpkg.pl and can be anything, though I would not recommend making it too small.
I doubt you are losing too many events unnecessarily though, you will probably permanently have only a couple deleted ahead of time and they would generally have been the next ones to go anyway.
Phil,
tommy
Post by tommy »
Thanks Phil. I misunderstood the fast delete option. I thought the "slow" delete would delete the events from the actual events directory. I now see it just does a complete delete from all the tables in the db. I know, I know, RTFM. But sometimes you read and just don't see it.
thanks for the replay
tommy
