Replay doesn't work with ZM_DIR_EVENTS=/mnt/hda2/events
A.Ottburg
Post by A.Ottburg »
Hi Phil,
Hi ZM users,
1.) I finished my cam-installation and the program is running fine, but when I change ZM_DIR_EVENTS (for ex.: /mnt/hda2/events) to store the events on another partition on my computer, the event-replay function does not work anymore.
This behavior is 100% reproducable. I tried out vfat and ext3 partition mode with the same behavior.
2.) If I change that option (ZM_DIR_EVENTS) I have to restart zm (what is clear), but in the console window I still see the disk usage of the previous setting (events that means disk usage on /dev/hda7 for my installation). I have to restart the Bowser to see the disk space of the actual setting.
3.) when starting zm the first time after rebooting I realize a red source
/dev/video0(1) and
/dev/video1(1)
in the console window. I have to restart zm to get video functional (amber or green). Any suggestions?
Best regards
Andreas Ottburg
P.S.:
SUSE 9.1
APACHE2 2.0.49
Kernel 2.6.5-111 (SUSE) and 2.6.9
dfaulkner
Re: Replay doesn't work with ZM_DIR_EVENTS=/mnt/hda2/events
Post by dfaulkner »
[quote="A.Ottburg"]
/quote]
I'm trying to do the same thing, so I did some poking about in the source. In zm_xhtml_view_event.php (and similarly in other locations):
$event_path = ZM_DIR_EVENTS.'/'.$event['MonitorName'].'/'.$event['Id'];
It appears that ZM_DIR_EVENTS is used not just as the filesystem path to events, but also as the web-relative path to events. This doesn't work if you move the event directory out of the web root, which is a common need.
I expect that the easiest solution is to leave the variables alone (ZM_DIR_EVENTS=events) and symlink from your large drive into the web root :
$ ln -s /mnt/hda2/events /var/www/html/events
I did change ZM_PATH_SOCKS and ZM_PATH_LOCKS, though, since I don't want that data in /tmp.
Here's what I did. I mounted my disk on /video, so:
bash# cd /var/www/html
bash# cp -a {events,images,sounds} /video
bash# mv events orig-events # (etc.)
bash# ln -s /video/events . # (etc.)
This seems to be working for me.
jameswilson
Post by jameswilson »
Thanks for that and for resurecting an old one!
I am about to embark on a test project using ISCSI and MDADM and LVM to see if the theory works. Using this approch will make it easier for me so thanks
James Wilson
dfaulkner
Post by dfaulkner »
jameswilson wrote:I am about to embark on a test project using ISCSI and MDADM and LVM to see if the theory works.
I'm not using LVM, but I am using software RAID1. My /video filesystem is md3 or something. I'm sure that LVM would work just fine in this case too, but I dropped it to save overhead since I don't plan on expanding beyond the system case.
Good luck with iSCSI. Let us know how it goes.
jameswilson
will do
James Wilson
vivi
Post by vivi »
A.Ottburg wrote:Hi Phil,
As for me, you have to change 2 lines in zm_funcs.php only.
Find getDiskPercent() and getDiskBlocks() functions and change the line:
$df = shell_exec ( 'df '.ZM_DIR_EVENTS );
with something like
$df = shell_exec ( 'df /mnt/hdd/' );
where /mnt/hdd/ is a path to yours new events storage place
