I'd like to connect 11 analog cameras using 2 boards like these PV-149
http://store.bluecherry.net/Provideo_PV ... pv-149.htm
in same machine. Can I have performance issues ? What are the minimum requirements in memory, processor and disk space for zoneminder in this situation ?
I have never found a benchmark or a study case about zoneminder. Can you give me some ?
thanks in advice
hardware requirements for ZM 1.24
You can start here - http://www.zoneminder.com/wiki/index.ph ... in_mind.29
You'll end up having to do some figuring on your own keeping in mind what resolutions you want to use, frame rates, what the capabilities of the cameras are, what rates do the cards support, colour versus grey scale, etc..
Here's a page with some charts you may find of help - http://stream.uen.org/medsol/digvid/htm ... chfit.html
