Getting some errors on ZM
Hi folks...
I'm not that good in English....
I'm getting some errors on zm like "kernel time sync error 1" and several "WAR [Buffer overrun at index N, slow down capture, speed up analysis or increasse ring buffer size]
I've tried several kind of "help" here in the forum, but no one had no effect...
I would really like some help here...
Thanks...
Thanks...
ipcs
chave shmid proprietário perms bytes nattch status
0x7a6d0001 0 www-data 700 11521268 2
0x7a6d0002 32769 www-data 700 11521268 2
0x7a6d0003 65538 www-data 700 11521268 2
0x7a6d0004 98307 www-data 700 11521268 2
0x7a6d0005 131076 www-data 700 11521268 2
0x7a6d0006 163845 www-data 700 11521268 2
0x7a6d0007 196614 www-data 700 11521268 2
------- Arrays de semáforos --------
chave semid proprietário perms nsems
0x00000000 0 www-data 600 1
----- Filas de mensagens -----
chave msqid proprietário perms bytes usados mensagens
ipcs -l
- Limites da memória compartilhada -
max number of segments = 4096
mas seg size (kbytes) = 262144
max total shared memory (kbytes) = 8388608
min seg size (bytes) = 1
------ Limites de semáforo ------
número máximo de arrays: 128
máximo de semáforos por array: 250
máximo geral de semáforos do sistema: 32000
máximo de ops por chamada semop: 32
valor máximo de semáforo: 32767
----- Mensagens: limites -----
número máximo geral defilas no sistema: 16
tamanho máximo da mensagem (bytes): 8192
tamanho máximo padrão da fila (bytes): 16384
So, i'm from Brasil...
I hope this help...it's a bit confused cause I don't know how to "space" properly...
Thanks for the Help
ipcs
ipcs -l
Thanks for the Help
I forgot to tell... the overruns are not the only problem... sometimes i have to restart the machine because the overrun problem... and when reboot it displays the error... "fsck died... on /dev/hdaN"... then I run "fsck /dev/hdaN" it's ok for a while... but sometimes when I reboot the linux this message appears... any ideas about this?
I'm having this exact problem, but I have 32 cameras running. I have increased the amount of shared memory (from 128 to 457MB), I increased the image buffer on all feeds to 60 from 40 and although I don't get as many, I still get some buffer overrun messages:
What other change can I make to give Zoneminder the amount of shared memory it needs for the 32 cameras?
Feb 18 04:50:05 camera zmc_dvideo1[9965]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
Feb 18 04:50:05 camera zmc_dvideo4[9949]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
Feb 18 05:04:55 camera zmc_dvideo9[9853]: WAR [Buffer overrun at index 44, slow down capture, speed up analysis or increase ring buffer size]
Feb 18 05:04:56 camera zmc_dvideo2[9957]: WAR [Buffer overrun at index 35, slow down capture, speed up analysis or increase ring buffer size]
Feb 18 05:04:56 camera zmc_dvideo7[9917]: WAR [Buffer overrun at index 1, slow down capture, speed up analysis or increase ring buffer size]
Feb 18 05:04:56 camera zmc_dvideo14[9813]: WAR [Buffer overrun at index 58, slow down capture, speed up analysis or increase ring buffer size]
Feb 18 05:04:57 camera zmc_dvideo8[9861]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
Feb 18 05:05:11 camera zmc_dvideo6[9933]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
Feb 18 05:05:28 camera zmc_dvideo12[9829]: WAR [Buffer overrun at index 0, slow down capture, speed up analysis or increase ring buffer size]
Feb 18 05:05:29 camera zma_m65[9833]: WAR [Approaching buffer overrun, consider slowing capture, simplifying analysis or increasing ring buffer size]
Feb 18 05:05:30 camera zmc_dvideo12[9829]: WAR [Buffer overrun at index 3, slow down capture, speed up analysis or increase ring buffer size]
Feb 18 05:05:54 camera zmc_dvideo11[9837]: WAR [Buffer overrun at index 39, slow down capture, speed up analysis or increase ring buffer size]
Feb 18 05:05:56 camera zmc_dvideo11[9837]: WAR [Buffer overrun at index 44, slow down capture, speed up analysis or increase ring buffer size]
