Illegal division by zero at /usr/bin/zmvideo.pl line 292.
madmax
Post by madmax »
I was getting movies mailed to myself for months and all of the sudden they stopped.
When I execute: /usr/bin/zmvideo.pl -e 7220 -r 1 -s 1 -f mov
Any ideas? I'm using v1.23.3
zoneminder
Site Admin
Post by zoneminder »
There is a zmvideo.log file plus there will be an ffmpeg.log file in each event directory that has had video generated. There may be something in there that helps.
Phil
madmax
Post by madmax »
Thanks.
I checked the ffmpeg.log file and it shows "Incorrect frame rate"
02/20/09 12:30:15.595455 zmfilter[6182].ERR [Video generation '/usr/bin/zmvideo.pl -e 7218 -r 1 -s 1 -f mov' failed with status: 255]
Any ideas why it would be picking up the wrong framerate?
cordel
Post by cordel »
Try setting the rate to 20 or 25 and see what happens.
-r 25
Have you made any changes before this started?
madmax
Post by madmax »
I have -r 25 in the config.
I do not recall making any changes. This is really strange. I'll keep digging.
madmax
Post by madmax »
It looks like it was getting hung up trying to encode some old events. Not sure what I change at that time but I just flagged all the events (update events set videoed = 1;) and now new events are working. I'll cross my fingers for now. Thanks!
cordel
Post by cordel »
Might run a test on the database just to make sure it is good.
satz
Post by satz »
I was getting the same error in zmvideo.pl for a camera that I am recording 0.1 frames a second which is basically one frame every 10 seconds. The Frames entry in the database looks like:
203461 60 Normal 2009-03-10 16:40:06 599.98 0
So delta is 599.98. It looks like the code to extract the event in zmvideo.pl:
my $sql = "select max(F.Delta)-min(F.Delta) as FullLength, E.*, unix_timestamp(E.StartTime) as Time, M.Name as MonitorName, M.Width as MonitorWidth, M.Height as MonitorHeight, M.Palette from Frames as F inner join Events as E on F.EventId = E.Id inner join Monitors as M on E.MonitorId = M.Id where EventId = '$event_id' group by F.EventId";
This will get 0 for FullLength for the above event frame. I added code to zmvideo.pl so that if FullLength is zero to set it to 1.
*** /usr/bin/zmvideo.pl-        2008-09-24 02:45:58.000000000 -0600
--- /usr/bin/zmvideo.pl 2009-03-10 19:27:20.000000000 -0600
*** 289,294 ****
--- 289,297 ----
        elsif ( ZM_OPT_MPEG eq "ffmpeg" )
+               if ($event->{FullLength} == 0) {
+                   $event->{FullLength} = 1;
                my $frame_rate = sprintf( "%.2f", $event->{Frames}/$event->{FullLength} );
                if ( $rate )
This allows me to get mpeg files via ffmpeg now.
chika_nidza
Post by chika_nidza »
I am having the same problem. The thing is that for some events, there's only one frame inserted into the Frames table, so the max(F.Delta)-min(F.Delta) always gives 0 for them.
I solved the problem by replacing max(F.Delta)-min(F.Delta) by max(F.Delta):
select max(F.Delta) as FullLength, E.*, unix_timestamp(E.StartTime) as Time, M.Name as MonitorName, M.Width as MonitorWidth, M.Height as MonitorHeight, M.Palette from Frames as F inner join Events as E on F.EventId = E.Id inner join Monitors as M on E.MonitorId = M.Id where EventId = '$event_id' group by F.EventId
This works fine for me, but I don't know if it will affect video generation in case the framerate isn't 25.
So does anyone know how come there's only one frame inserted for some videos, and why is FullLength calculated by substracting the deltas?
Thanks.
