Build problems with Centos 5.2
mycal
Post by mycal »
I'm getting the following scope error
zm_ffmpeg_camera.cpp: In member function ‘virtual int FfmpegCamera::PrimeCapture()’:
zm_ffmpeg_camera.cpp:125: error: ‘SWS_BICUBIC’ was not declared in this scope
zm_ffmpeg_camera.cpp:125: error: ‘sws_getCachedContext’ was not declared in this scope
zm_ffmpeg_camera.cpp: In member function ‘virtual int FfmpegCamera::Capture(Image&)’:
zm_ffmpeg_camera.cpp:156: error: ‘sws_scale’ was not declared in this scope
make[2]: *** [zm_ffmpeg_camera.o] Error 1
make[2]: Leaving directory `/root/zoneminder_install/ZoneMinder-1.24.0/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/root/zoneminder_install/ZoneMinder-1.24.0'
make: *** [all] Error 2
I've seem other people with similar errors, I've tried the top of tree ffmpeg and
svn checkout -r 17338 svn://svn.mplayerhq.hu/ffmpeg/trunk ffmpeg
configure for ffmpeg ./configure --enable-swscale --enable-gpl
Should I be using a specific version of ffmpeg?
Anything else I should look at?
Mycal
PS no ccache installed
zoneminder
Site Admin
Post by zoneminder »
When you ran configure for ZM do you know if it found the swscale headers and libraries? It should say in config.log if you are not sure.
Phil
mycal
Post by mycal »
Your right it's not finding it. For some reason that paths are screwed up. I'm getting
-I/usr/loca/bin ...
dropping the l in local.
Trying to find out why now.
darn, now that I edited the file I cannot reproduce, everything working. I'll try unpacking the file again and see if it comes back and let you know.
-M
