I have added a SVN roll-up patch to the Patches section of the Wiki as well as the RTSP Authentication patch for ffmpeg inf anyone needs that before it is included in their distribution.
The roll-up patch is basically just diffs between the 1.24.0 release and the current SVN available from http://svn.zoneminder.com for people who can't, or prefer not to, use svn. If you are reporting issues it would be useful if you could try the fixes included in svn or the patch to see if it is something already fixed. This patch will be periodically updated when significant fixes are generated ahead of a 1.24.1 release shortly.
1.24.0 Updates
- zoneminder
- Site Admin
- Contact:
- zoneminder
- Site Admin
- Contact:
- zoneminder
- Site Admin
- Contact:
Yes. It won't do any harm if you run it as often as you like but it is necessary when new config is added or removed just to make sure that it is updated in the DB. It won't affect any of your existing settings just add missing ones and deleted defunct ones.
There was no need for the 1.24 updates until the last one or two so most of the time you don't need to bother but if you see a config items mismatch in your logs then that is a clue to run it.
Phil
