Now saved brightness, contrast. hue and colour for monitors.
oskin
Post by oskin »
This patch fixed a bug published in http://www.zoneminder.com/forums/viewtopic.php?t=3437.
Database update required:
alter table Monitors add column Brightness mediumint(5) unsigned NOT NULL default '32767' after RefBlendPerc;
alter table Monitors add column Contrast mediumint(5) unsigned NOT NULL default '32767' after Brightness;
alter table Monitors add column Hue mediumint(5) unsigned NOT NULL default '32767' after Contrast;
alter table Monitors add column Colour mediumint(5) unsigned NOT NULL default '32767' after Hue;
Download patch[/code]
oskin
Post by oskin »
zoneminder
Site Admin
Post by zoneminder »
Hi Oskin,
I am trying to apply this patch for 1.19.5 but I believe that the patch for zm_local_camera.cpp is reversed, can you confirm this?
Phil,
oskin
Post by oskin »
First it is necessary to apply a patch http://www.zoneminder.com/forums/viewtopic.php?t=3424. By changes in version 1.19.5 I have understood, that the problem is solved. :)
