ZM can't stream video
spitzmann007
Post by spitzmann007 »
I'm using debian lenny and I have compiled zm 1.23 debian's source package. After configuration now it works well but I can use just with m-jpeg. I can't use stream.
I installed the binary ffmpeg from apt-get and other software dependencies for zm compilation. then I did the compilation of zm 1.23
Is it some hint for troubleshooting zm's stream ?
volkan2k
Post by volkan2k »
try this one
you have to set the camera resolution and the monitior resolution at the same one
spitzmann007
analog cameras
volkan2k wrote:try this one
I'm using only analog cameras. They have 420L each.
softland
Post by softland »
Have you configured the "cambozola.jar" file?
I had the same error but this just solved
spitzmann007
softland wrote:Hi,
I didn't anything with .jar file. I just used the ant to make it.
How can I set up cambozola.jar file ?
softland
Post by softland »
You have to download the file (wget http://www.zoneminder.com/fileadmin/dow ... bozola.jar)
after this, copy the file to the zoneminder directory (cp cambozola.jar /var/www/zm/)
then reboot the linux and when you access zm console on IE, go to "options". on "images" tab, set ZM_CAN_STREAM > auto, ZM_STREAM_METHOD > jpeg, ZM_OPT_CAMBOZOLA > true and ZM_PATH_CAMBOZOLA > cambozola.jar
this should work...
