Problem with zmaudit
Fvzzl3
Post by Fvzzl3 »
after some minutes of capturing data the stream stops and i am not longer able to connect to zoneminder.
/var/log/messages shows following messages:
Feb 28 17:17:20 homeserver zmaudit[14377]: INF [Filesystem event '1/119' does not exist in database]
Feb 28 17:17:20 homeserver zmaudit[14377]: INF [deleting]
Feb 28 17:17:20 homeserver zmaudit[14377]: INF [Filesystem event '1/120' does not exist in database]
Feb 28 17:17:20 homeserver zmaudit[14377]: INF [Found orphaned frame records for event '119']
Feb 28 17:17:20 homeserver zmaudit[14377]: INF [Found orphaned frame records for event '120']
Feb 28 17:17:21 homeserver zmaudit[14377]: INF [Found orphaned statistic records for event '119']
Feb 28 17:17:21 homeserver zmaudit[14377]: INF [deleting]
Feb 28 17:17:21 homeserver zmaudit[14377]: INF [Found orphaned statistic records for event '120']
Do you know what this means?
Regards,
Fvzzl3
anupmankar
Post by anupmankar »
This is the audit script working normally. It did not find files for these events in the "event" directory. Since records related to these events were found in the database it is removing these records.
Fvzzl3
Post by Fvzzl3 »
okay, thanks
