the apache server hang/crashes after a while (after 5 mn) when displaying
continuously the picture coming from a camera .
if i restart apache , it works again for about 5 mn and crashes again .
ZM is 1.24 rev 3740
i get those errors in the apache log :
[code][Sun Feb 08 15:50:14 2009] [error] [client 192.168.4.3] socket_sendto( /tmp/zms-862368s.sock ) failed: No such file or directory, referer: http://venus/index.php?view=watch&mid=13
[Sun Feb 08 15:50:14 2009] [error] [client 192.168.4.3] array (\n 0 => \n array (\n 'file' => '/var/www/html/ajax/stream.php',\n 'line' => 51,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-862368s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/html/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/html/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://venus/index.php?view=watch&mid=13
[Sun Feb 08 15:50:20 2009] [error] [client 192.168.4.3] socket_sendto( /tmp/zms-434994s.sock ) failed: No such file or directory, referer: http://venus/index.php?view=watch&mid=12
[Sun Feb 08 15:50:20 2009] [error] [client 192.168.4.3] array (\n 0 => \n array (\n 'file' => '/var/www/html/ajax/stream.php',\n 'line' => 51,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-434994s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/html/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/html/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://venus/index.php?view=watch&mid=12
[Sun Feb 08 15:50:24 2009] [error] [client 192.168.4.3] socket_sendto( /tmp/zms-862368s.sock ) failed: No such file or directory, referer: http://venus/index.php?view=watch&mid=13
[Sun Feb 08 15:50:24 2009] [error] [client 192.168.4.3] array (\n 0 => \n array (\n 'file' => '/var/www/html/ajax/stream.php',\n 'line' => 51,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-862368s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/html/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/html/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://venus/index.php?view=watch&mid=13
[Sun Feb 08 16:00:12 2009] [warn] [client 192.168.4.3] Timeout waiting for output from CGI script /var/www/cgi-bin/nph-zms, referer: http://venus/index.php?view=watch&mid=19
