zoneminder behind apache2 proxy error...
szimszon
Post by szimszon »
Hello!
I wonder if somebody could help me.
I tried to run zoneminder behind an apache2 proxy - why? it's a long story.
But after I log in to zoneminder I got this answer:
  <script type="text/javascript" src="tools/mootools/mootools.js"></script>
  <script type="text/javascript" src="js/mootools.ext.js"></script>
  <script type="text/javascript">
  var AJAX_TIMEOUT = 10000;
  var currentView = 'postlogin';
  var thisUrl = "http://192.168.55.2/zm/index.php";
  var skinPath = "skins/classic";
  var canEditSystem = true;
  var canViewSystem = true;
  var refreshParent = false;
  var focusWindow = false;
In that answer I got:
I think it is calculated from the request but it's in the body so apache can't rewrite it to something like http://domain.tld/zm/index.php
Is it possible to use relative urls in javascript and html code?
Thank you!
zoneminder
Site Admin
Post by zoneminder »
Can you try and edit web/skins/classic/js/skin.js.php and find the line
  var thisUrl = "<?= ZM_BASE_URL.$_SERVER['PHP_SELF'] ?>";
and change it to
var thisUrl = "<?= $_SERVER['PHP_SELF'] ?>";
and see if that makes any difference?
I'm not sure it will as some of the ajax requests need to use a full url I think but give it a try. Or you can edit web/index.php and hardcode the ZM_BASE_URL to your desired value.
Phil
trschober
Post by trschober »
I've not tried 1.24 yet, but in 1.23, you could edit /usr/share/zoneminder/zm.php
and change the line that goes
define( "ZM_BASE_URL", $protocol.'://'.$_SERVER['HTTP_HOST'] );
for
define( "ZM_BASE_URL", 'http://your.server.address.as.seen.from.outside' );
I've been doing that for a while so ZM works behind an apache proxy
hope it helps!
