Color Palette.... is off
quentusrex
Post by quentusrex »
White colors look green/yellow...
I can't seem to find the fix...
quentusrex
Here is the sample:
http://kingsestate.com/node/10
zoneminder
Site Admin
Post by zoneminder »
I think a little (=lot) more detail would be helpful here. Cam type, model? Palette selected? Basically any and everything you can supply would be helpful. There's not much to go on otherwise.
Phil
quentusrex
I don't know the brand or model. It's a generic bullet camera that I got from bluecherry a year or so ago. When I open it up in xawtv it looks fine. but Zoneminder has the colors all off...
If there is a list of commands I can run I'll run them and post the output here. I'm running Zoneminder trunk(as of 1-2 days ago).
I followed this guide. http://www.zoneminder.com/forums/viewtopic.php?t=13140
And only had to edit two source files. the one about the H264 and the one about the alloc line.
lspci:
02:08.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
02:08.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
02:09.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
02:09.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
02:0a.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
02:0a.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
02:0b.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
02:0b.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Ubuntu 8.10
Linux CameraShuttle 2.6.27-7-server #1 SMP Fri Oct 24 07:37:55 UTC 2008 i686 GNU/Linux
It's in a Shuttle box.(I don't remember the model.)
zmu -d /dev/video0 -q -v
Video Capabilities
Name: BT878 video (ProVideo PV150)
Type: 45
Can capture
Does teletext
Overlay onto frame buffer
Can clip
Video Channels: 2
Audio Channels: 0
Maximum Width: 768
Maximum Height: 480
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 0 - Unknown
Colour Depth: 32
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
Channel 1 Attributes
Channel: 1
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
Does that help? any more info needed? I can easily test patches.
quentusrex
Oh, and for the settings on the web console. I tried all the NTSC and they all seem the same, and I tried the RGB 32. the RGB 24 seemed to not pick anything up.
Actually it seems the camera is a: Q-see color camera
Model: Q0CDC
System: NTSC
Power: DC12v
Video output: 1.0vp-P75ohm
quentusrex
I tried YUV420 and that looks better except the lines seems shifted during movement. Like some of the individual horizontal lines are shifted either left or right.
derekfl
Re: Color Palette.... is off
Post by derekfl »
quentusrex wrote:White colors look green/yellow...
I am having the exact same issue with the exact same card. Everything looks fine in xawtv, but whites look green/yellow in ZoneMinder. Pictures also jump a lot.
