compiling ZM 1.24
compiling ZM 1.24
I tried to compile ZM 1.24 on debian etch. During the checks made by ./configure it showed me dependencies fails.
I have searched for a list with libraries and packages required for zm compilation. is there any ?
Debain Etch is going to need a whole bunch of dependencies to get zoneminder installed.. Been there... done that..
Try using ubuntu or kubuntu and you will have much better luck..
go look for 1.24 install DVD and you will find a free install on kubuntu 8.04.. It is not the latest 1.24.0 but it works...
newvisionantenna also made a new one that has 1.24.0 and the latest ffmpeg on it too.. You can check out the demo page of it running on a hosted VPS server also..
The VPS demo page is here:
http://67.210.200.98/
Take care,
Chuck D
Take care,
Chuck D
[quote="Chuck D"]Debain Etch is going to need a whole bunch of dependencies to get zoneminder installed.. Been there... done that..
Take care,
Chuck D[/quote
Ok, I'll try ubuntu. I have tried Ubuntu 8.10 however it doesn't work with my generic bt878 board ! This board is a cheap with a bt878 chip for 4 ports and it's sold with a pico2000 software. I made some experiences with that board for example booting the system without the board and then it works again. Probably it's something wrong with the kernel modules for thar board. I successfully tested the board with fedora 8. it works very well but I'm looking a more stable system with less memory consumption, then, I tried debian.
Take care,
Chuck D[/quote
I just did a quick glance at this link, but it might help you.
http://ubuntuforums.org/showthread.php? ... 0&t=153935
If it ends up working or if I can help you get it working, I'll include it in my dvd via an update. Might need the exact part number or model number.
I've never used one of the cards, but is it something like this?
https://wiki.ubuntu.com/HardwareSupport ... aGeovision
or
http://www.zoneminder.com/wiki/index.ph ... ip_8inputs
or
ZoneMinder Debian package dependencies
I think this could be the package dependency list for Debian Lenny, excluding X.10 support (home automation).
DEV-packages for compiling
build-essential
debhelper
autoconf
dpatch
libphp-serialization-perl
libgnutls-dev
libmysqlclient15-dev
libdbd-mysql-perl
libdate-manip-perl
libwww-perl
libjpeg62-dev
libpcre3-dev
libavcodec-dev
libavformat-dev
libavutil-dev
libavutil-dev
libbz2-dev
Requirements for running pre-compiled ZM, excluding X.10 support
apache2
mysql-client
mysql-server
php5
php5-mysql
netpbm
libpcre3
zlib1g
libstdc++6
libwww-perl
libmime-perl
libmime-lite-perl
libjpeg62
libgnutls26
libc6
libgcc1
libdevice-serialport-perl
libdate-manip-perl
libavutil49
libavformat52
libavcodec51
libarchive-tar-perl
libarchive-zip-perl
libapache2-mod-php5
ffmpeg
build-essential
debhelper
autoconf
dpatch
libgnutls-dev
libdbd-mysql-perl
libdate-manip-perl
libwww-perl
libjpeg62-dev
libpcre3-dev
libavcodec-dev
libavformat-dev
libavutil-dev
libavutil-dev
libbz2-dev
apache2
mysql-client
mysql-server
php5
php5-mysql
netpbm
libpcre3
zlib1g
libstdc++6
libwww-perl
libmime-perl
libmime-lite-perl
libjpeg62
libgnutls26
libc6
libgcc1
libdate-manip-perl
libavutil49
libavformat52
libavcodec51
libarchive-tar-perl
libarchive-zip-perl
libapache2-mod-php5
ffmpeg
Have you looked in the kernel docs for the info on getting a bt878 working? There is a pretty extensive list of these card types and the module parameters required to get them working.This board is a cheap with a bt878 chip for 4 ports and it's sold with a pico2000 software.
This may help too. http://www.zoneminder.com/wiki/index.php/Pico2000
Why checking ... no?
I compile ZM 1.24:
My ffmpeg:
Why checking ... no?....
checking libavutil/avutil.h usability... yes
checking libavutil/avutil.h presence... yes
checking for libavutil/avutil.h... yes
checking ffmpeg/avutil.h usability... no
checking ffmpeg/avutil.h presence... no
checking for ffmpeg/avutil.h... no
checking libavcodec/avcodec.h usability... yes
checking libavcodec/avcodec.h presence... yes
checking for libavcodec/avcodec.h... yes
checking ffmpeg/avcodec.h usability... no
checking ffmpeg/avcodec.h presence... no
checking for ffmpeg/avcodec.h... no
checking libavformat/avformat.h usability... yes
checking libavformat/avformat.h presence... yes
checking for libavformat/avformat.h... yes
checking ffmpeg/avformat.h usability... no
checking ffmpeg/avformat.h presence... no
checking for ffmpeg/avformat.h... no
checking libswscale/swscale.h usability... yes
checking libswscale/swscale.h presence... yes
checking for libswscale/swscale.h... yes
checking ffmpeg/swscale.h usability... no
checking ffmpeg/swscale.h presence... no
checking for ffmpeg/swscale.h... no
checking pcre/pcre.h usability... no
checking pcre/pcre.h presence... no
checking for pcre/pcre.h... no
checking pcre.h usability... yes
checking pcre.h presence... yes
My ffmpeg:
$ ffmpeg
FFmpeg version SVN-r17469-svn17461+3:0.svn20090220, Copyright (c) 2000-2009 Fabrice Bellard, et al.
configuration: --prefix=/usr --enable-gpl --enable-postproc --enable-pthreads --enable-swscale --enable-x11grab --enable-libfaac --enable-libfaad --extra-version=svn17461+3:0.svn20090220 --enable-avfilter --enable-avfilter-lavf --enable-libmp3lame --enable-libtheora --enable-libx264 --enable-libxvid --enable-avfilter --enable-avfilter-lavf --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libvorbis --enable-pthreads --enable-vdpau --enable-libdc1394 --enable-shared
libavutil 49.14. 0 / 49.14. 0
libavcodec 52.18. 0 / 52.18. 0
libavformat 52.29. 2 / 52.29. 2
libavdevice 52. 1. 0 / 52. 1. 0
libavfilter 0. 3. 0 / 0. 3. 0
libswscale 0. 7. 0 / 0. 7. 0
libpostproc 51. 2. 0 / 51. 2. 0
built on Feb 20 2009 12:56:03, gcc: 4.3.2
At least one output file must be specified
Re: Why checking ... no?
Because the header isn't being found where it's looking. Not to worry, in each case it has been found. Read it again. You're good to go.VyacheslavS wrote:Why checking ... no?
I enjoy a challenge...
On Lenny:
debiwan ZoneMinder-1.24.1 # uname -a
Linux debiwan 2.6.26-1-686 #1 SMP Sat Jan 10 18:29:31 UTC 2009 i686 GNU/Linux
FFmpeg version r11872+debian_0.svn20080206-17, Copyright (c) 2000-2008 Fabrice Bellard, et al.
configuration: --enable-gpl --enable-libfaad --enable-pp --enable-swscaler --enable-x11grab --prefix=/usr --enable-libgsm --enable-libtheora --enable-libvorbis --enable-pthreads --disable-strip --enable-libdc1394 --disable-armv5te --disable-armv6 --disable-altivec --disable-vis --enable-shared --disable-static
libavutil version: 49.6.0
libavcodec version: 51.50.0
libavformat version: 52.7.0
libavdevice version: 52.0.0
built on Feb 10 2009 08:13:56, gcc: 4.3.3
debiwan ZoneMinder-1.24.1 # ./configure --with-webdir=/var/www/zm --with-cgidir=/var/www/cgi-bin
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
configure: WARNING: You can call configure with the --with-libarch option.
This tells configure where to find architecture specific libraries.
The default of 'lib' is usually ok but 64 bit machines may require lib64.
e.g. --with-libarch=lib or --with-libarch=lib64
configure: WARNING: You can call configure with the --with-mysql option.
This tells configure where to find the MySql C library and headers if configure cannot
locate them automatically.
e.g. --with-mysql=/usr/local or --with-mysql=/usr
configure: WARNING: You can call configure with the --with-ffmpeg option.
This tells configure where to find the ffmpeg root directory within which are the libavcodec
and libavformat files that can be used to build true MPEG streaming into ZoneMinder. Ensure that
your copy of ffmpeg has installed libraries as well as binaries (use 'make installlib'). If you
are using a local install of ffmpeg you may have to remove or rename a previous real installation
as the headers and libraries from that will probably be picked up before your local copy.
e.g. --with-ffmpeg=/usr/local
configure: WARNING: You can call configure with the --with-extralibs option.
Ordinarily you will need to use this option only when your copy of ffmpeg has been built
with support for additional formats and you would use this option to detail which additional
libraries ffmpeg was built with so that it is able to link successfully with ZoneMinder.
You will need to wrap this option in quotes if it contains any spaces.
e.g. --with-extralibs="-lmp3lame"
configure: WARNING: You can call configure with the --with-webuser option.
This tells configure what the user name of the web user is if it is not the default of 'apache'.
e.g. --with-webuser=apache or --with-webuser=web
configure: WARNING: You can call configure with the --with-webgroup option.
This tells configure what the group name of the web group is if it is not the default of 'apache'.
e.g. --with-webgroup=apache or --with-webgroup=web
configure: WARNING: You can call configure with the --enable-debug=<yes> or --disable-debug option.
This tells configure whether to compile ZoneMinder with debug included. Although debug is included
by default it is not output unless explicitly switched on elsewhere. These checks may induce a
small penalty on performance and if you are after squeezing the maximum possible performance out
of ZoneMinder you may use this switch to prevent debug from being compiled in.
e.g. --enable-debug=yes or --disable-debug
configure: WARNING: You can call configure with the --enable-crashtrace=<yes> or --disable-crashtrace option.
This tells configure whether to compile ZoneMinder with crash tracing included. This allows a
dump of the stack trace when a ZoneMinder binary crashes or is killed by an unexpected signal.
Although this should work on most systems it does rely on un(or loosely) documented features and
so should be regarded as experimental. If you experience problems compiling zm_signal.cpp or
ZoneMinder binaries fail to shut down correctly then you should probably disable this feature.
e.g. --enable-crashtrace=yes or --disable-crashtrace
configure: WARNING: You can call configure with the --enable-mmap=<yes> or --disable-mmap option.
This tells configure whether to compile ZoneMinder with mmap support rather than IPC shared
memory. This is an experimental feature that uses memory mapped into files which all processes
can share. Memory mapping requires less configuration and is more flexible than shared memory
but may slow down your system unless the mapped files are configured to reside on a fast or
RAM based filesystem.
e.g. --enable-mmap=yes or --disable-mmap
checking for g++... g++
checking for C++ compiler default output file name... a.out
checking whether the C++ compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for style of include used by make... GNU
checking dependency style of g++... gcc3
checking for gcc... gcc
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking dependency style of gcc... gcc3
checking whether ln -s works... yes
checking for ranlib... ranlib
checking whether make sets $(MAKE)... (cached) yes
checking how to run the C++ preprocessor... g++ -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for stdbool.h that conforms to C99... yes
checking for _Bool... no
checking for an ANSI C-conforming const... yes
checking for uid_t in sys/types.h... yes
checking for inline... inline
checking for mode_t... yes
checking for size_t... yes
checking for ssize_t... yes
checking whether time.h and sys/time.h may both be included... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking for uint8_t... yes
checking return type of signal handlers... void
checking for siginfo_t... yes
checking for struct sigcontext... yes
checking for struct sigcontext.eip... yes
checking for ucontext_t... yes
checking whether gcc needs -traditional... no
checking for stdlib.h... (cached) yes
checking for GNU libc compatible malloc... yes
checking for unistd.h... (cached) yes
checking for getpagesize... yes
checking for working mmap... yes
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking types of arguments for select... int,fd_set *,struct timeval *
checking whether lstat dereferences a symlink specified with a trailing slash... yes
checking whether stat accepts an empty string... no
checking for strftime... yes
checking for working strtod... yes
checking for vprintf... yes
checking for _doprnt... no
checking for gethostbyname... yes
checking for gethostname... yes
checking for gettimeofday... yes
checking for memmove... yes
checking for memset... yes
checking for mkdir... yes
checking for munmap... yes
checking for putenv... yes
checking for select... yes
checking for socket... yes
checking for sqrt... yes
checking for strcasecmp... yes
checking for strchr... yes
checking for strcspn... yes
checking for strerror... yes
checking for strncasecmp... yes
checking for strrchr... yes
checking for strsignal... yes
checking for strspn... yes
checking for strstr... yes
checking for strtol... yes
checking for strtoull... yes
checking for ffmpeg... yes
checking for ffmpeg... /usr/bin/ffmpeg
checking for pnmscale... yes
checking for pnmscale... /usr/bin/pnmscale
checking for jpeg_start_compress in -ljpeg... yes
checking for compress in -lz... yes
checking for dlsym in -ldl... yes
checking for pthread_create in -lpthread... yes
checking for mysql_init in -lmysqlclient... yes
checking for MD5 in -lgnutls-openssl... yes
checking for pcre_compile in -lpcre... yes
checking for av_malloc in -lavutil... yes
checking for avcodec_init in -lavcodec... yes
checking for av_new_stream in -lavformat... yes
checking for sws_scale in -lswscale... yes
checking for BZ2_bzCompress in -lbz2... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for ANSI C header files... (cached) yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking for memory.h... (cached) yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for string.h... (cached) yes
checking for strings.h... (cached) yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for sys/socket.h... (cached) yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking syslog.h usability... yes
checking syslog.h presence... yes
checking for syslog.h... yes
checking values.h usability... yes
checking values.h presence... yes
checking for values.h... yes
checking linux/videodev.h usability... yes
checking linux/videodev.h presence... yes
checking for linux/videodev.h... yes
checking linux/videodev2.h usability... yes
checking linux/videodev2.h presence... yes
checking for linux/videodev2.h... yes
checking mysql/mysql.h usability... yes
checking mysql/mysql.h presence... yes
checking for mysql/mysql.h... yes
checking libavutil/avutil.h usability... no
checking libavutil/avutil.h presence... no
checking for libavutil/avutil.h... no
checking ffmpeg/avutil.h usability... yes
checking ffmpeg/avutil.h presence... yes
checking for ffmpeg/avutil.h... yes
checking libavcodec/avcodec.h usability... no
checking libavcodec/avcodec.h presence... no
checking for libavcodec/avcodec.h... no
checking ffmpeg/avcodec.h usability... yes
checking ffmpeg/avcodec.h presence... yes
checking for ffmpeg/avcodec.h... yes
checking libavformat/avformat.h usability... no
checking libavformat/avformat.h presence... no
checking for libavformat/avformat.h... no
checking ffmpeg/avformat.h usability... yes
checking ffmpeg/avformat.h presence... yes
checking for ffmpeg/avformat.h... yes
checking libswscale/swscale.h usability... no
checking libswscale/swscale.h presence... no
checking for libswscale/swscale.h... no
checking ffmpeg/swscale.h usability... yes
checking ffmpeg/swscale.h presence... yes
checking for ffmpeg/swscale.h... yes
checking for pcre.h... yes
checking sys/ipc.h usability... yes
checking sys/ipc.h presence... yes
checking for sys/ipc.h... yes
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking whether round is declared... yes
checking whether MD5 is declared... yes
checking whether backtrace is declared... yes
checking for perl... perl
checking for perl version greater than or equal to 5.6.0... ok
checking for perl module Sys::Syslog... ok
checking for perl module DBI... ok
checking for perl module DBD::mysql... ok
checking for perl module Getopt::Long... ok
checking for perl module Time::HiRes... ok
checking for perl module Date::Manip... ok
checking for perl module LWP::UserAgent... ok
checking for perl module PHP::Serialization... ok
checking for perl module Module::Load... ok
checking for perl module Device::SerialPort... ok
checking for perl module Net::FTP... ok
checking for perl module Archive::Tar... ok
checking for perl module Archive::Zip... ok
checking for perl module Net::SMTP... ok
checking for perl module MIME::Lite... ok
checking for perl module MIME::Entity... ok
checking for perl module X10::ActiveHome... no
configure: WARNING: X10::ActiveHome is required for X.10 support
configure: creating ./config.status
config.status: creating Makefile
config.status: creating zm.conf
config.status: creating db/Makefile
config.status: creating db/zm_create.sql
config.status: creating scripts/Makefile
config.status: creating scripts/zm
config.status: creating scripts/zmdbbackup
config.status: creating scripts/zmdbrestore
config.status: creating scripts/zmeventdump
config.status: creating scripts/zmlogrotate.conf
config.status: creating scripts/ZoneMinder/lib/ZoneMinder/Base.pm
config.status: creating scripts/ZoneMinder/lib/ZoneMinder/Config.pm
config.status: creating scripts/ZoneMinder/lib/ZoneMinder/Memory.pm
config.status: creating scripts/ZoneMinder/lib/ZoneMinder/ConfigAdmin.pm
config.status: creating src/Makefile
config.status: creating src/zm_config.h
config.status: creating web/Makefile
config.status: creating web/ajax/Makefile
config.status: creating web/css/Makefile
config.status: creating web/graphics/Makefile
config.status: creating web/includes/Makefile
config.status: creating web/includes/config.php
config.status: creating web/js/Makefile
config.status: creating web/lang/Makefile
config.status: creating web/skins/Makefile
config.status: creating web/skins/classic/Makefile
config.status: creating web/skins/classic/ajax/Makefile
config.status: creating web/skins/classic/css/Makefile
config.status: creating web/skins/classic/graphics/Makefile
config.status: creating web/skins/classic/includes/Makefile
config.status: creating web/skins/classic/js/Makefile
config.status: creating web/skins/classic/lang/Makefile
config.status: creating web/skins/classic/views/Makefile
config.status: creating web/skins/classic/views/css/Makefile
config.status: creating web/skins/classic/views/js/Makefile
config.status: creating web/skins/mobile/Makefile
config.status: creating web/skins/mobile/ajax/Makefile
config.status: creating web/skins/mobile/css/Makefile
config.status: creating web/skins/mobile/graphics/Makefile
config.status: creating web/skins/mobile/includes/Makefile
config.status: creating web/skins/mobile/lang/Makefile
config.status: creating web/skins/mobile/views/Makefile
config.status: creating web/skins/mobile/views/css/Makefile
config.status: creating web/tools/Makefile
config.status: creating web/tools/mootools/Makefile
config.status: creating web/views/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
checking for scripts/ZoneMinder/Makefile... yes
debiwan ZoneMinder-1.24.1 # make
make all-recursive
make[1]: Entering directory `/usr/local/src/ZoneMinder-1.24.1'
Making all in src
make[2]: Entering directory `/usr/local/src/ZoneMinder-1.24.1/src'
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zmc.o -MD -MP -MF .deps/zmc.Tpo -c -o zmc.o zmc.cpp
mv -f .deps/zmc.Tpo .deps/zmc.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm_box.o -MD -MP -MF .deps/zm_box.Tpo -c -o zm_box.o zm_box.cpp
mv -f .deps/zm_box.Tpo .deps/zm_box.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm_buffer.o -MD -MP -MF .deps/zm_buffer.Tpo -c -o zm_buffer.o zm_buffer.cpp
mv -f .deps/zm_buffer.Tpo .deps/zm_buffer.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm_camera.o -MD -MP -MF .deps/zm_camera.Tpo -c -o zm_camera.o zm_camera.cpp
mv -f .deps/zm_camera.Tpo .deps/zm_camera.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm_comms.o -MD -MP -MF .deps/zm_comms.Tpo -c -o zm_comms.o zm_comms.cpp
mv -f .deps/zm_comms.Tpo .deps/zm_comms.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm_config.o -MD -MP -MF .deps/zm_config.Tpo -c -o zm_config.o zm_config.cpp
mv -f .deps/zm_config.Tpo .deps/zm_config.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm_coord.o -MD -MP -MF .deps/zm_coord.Tpo -c -o zm_coord.o zm_coord.cpp
mv -f .deps/zm_coord.Tpo .deps/zm_coord.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm.o -MD -MP -MF .deps/zm.Tpo -c -o zm.o zm.cpp
mv -f .deps/zm.Tpo .deps/zm.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm_db.o -MD -MP -MF .deps/zm_db.Tpo -c -o zm_db.o zm_db.cpp
mv -f .deps/zm_db.Tpo .deps/zm_db.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm_event.o -MD -MP -MF .deps/zm_event.Tpo -c -o zm_event.o zm_event.cpp
mv -f .deps/zm_event.Tpo .deps/zm_event.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm_exception.o -MD -MP -MF .deps/zm_exception.Tpo -c -o zm_exception.o zm_exception.cpp
mv -f .deps/zm_exception.Tpo .deps/zm_exception.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm_file_camera.o -MD -MP -MF .deps/zm_file_camera.Tpo -c -o zm_file_camera.o zm_file_camera.cpp
mv -f .deps/zm_file_camera.Tpo .deps/zm_file_camera.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm_ffmpeg_camera.o -MD -MP -MF .deps/zm_ffmpeg_camera.Tpo -c -o zm_ffmpeg_camera.o zm_ffmpeg_camera.cpp
mv -f .deps/zm_ffmpeg_camera.Tpo .deps/zm_ffmpeg_camera.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm_image.o -MD -MP -MF .deps/zm_image.Tpo -c -o zm_image.o zm_image.cpp
zm_image.cpp: In member function 'void Image::Blend(const Image&, int) const':
zm_image.cpp:776: warning: operation on 'pdest' may be undefined
mv -f .deps/zm_image.Tpo .deps/zm_image.Po
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include -frepo -g -O2 -MT zm_local_camera.o -MD -MP -MF .deps/zm_local_camera.Tpo -c -o zm_local_camera.o zm_local_camera.cpp
zm_local_camera.cpp: In function 'PixelFormat getFfPixFormatFromV4lPalette(int, int)':
zm_local_camera.cpp:161: error: 'PIX_FMT_VDPAU_H264' was not declared in this scope
zm_local_camera.cpp:162: error: 'PIX_FMT_VDPAU_MPEG1' was not declared in this scope
zm_local_camera.cpp:163: error: 'PIX_FMT_VDPAU_MPEG2' was not declared in this scope
zm_local_camera.cpp:228: error: 'PIX_FMT_VDPAU_H264' was not declared in this scope
zm_local_camera.cpp:229: error: 'PIX_FMT_VDPAU_MPEG1' was not declared in this scope
zm_local_camera.cpp:230: error: 'PIX_FMT_VDPAU_MPEG2' was not declared in this scope
make[2]: *** [zm_local_camera.o] Error 1
make[2]: Leaving directory `/usr/local/src/ZoneMinder-1.24.1/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/local/src/ZoneMinder-1.24.1'
make: *** [all] Error 2
debiwan ZoneMinder-1.24.1 # locate avutil.h
/usr/include/ffmpeg/avutil.h
debiwan ZoneMinder-1.24.1 # locate avcodec.h
/usr/include/ffmpeg/avcodec.h
debiwan ZoneMinder-1.24.1 # locate avformat.h
/usr/include/ffmpeg/avformat.h
debiwan ZoneMinder-1.24.1 # locate swscale.h
/usr/include/ffmpeg/swscale.h
debiwan ZoneMinder-1.24.1 # locate pcre.h
/usr/include/pcre.h
What did I miss?
On Lenny:
make all-recursive
Making all in src
/usr/include/pcre.h
What did I miss?
I think there should be a sticky on this error or variant's of it. Try a newer ffmpeg or go into and hand edit zm_local_camera.cpp. You will find two seperate instances of the offending lines. I think one is about half way down and the other about 3/4 the way. Just put // in front of the lines giving error and it will build.
Hope that helps, I remember when this first happened and it's still getting people now.
Next make:
zm_rtsp.cpp: In constructor 'RtspThread::RtspThread(int, RtspThread::RtspMethod, const std::string&, const std::string&, const std::string&, const std::string&, const std::string&, const std::string&)':
zm_rtsp.cpp:183: error: 'avformat_alloc_context' was not declared in this scope
make[2]: *** [zm_rtsp.o] Error 1
Closer!
Closer!
I figured that would be next, one sec. I'll brb.
Here you go,
zm_rtsp.cpp at or around line 183 change avformat to the av_alloc.... line
- mFormatContext = avformat_alloc_context();
+ mFormatContext = av_alloc_format_context();
That's taken from this post,
http://www.zoneminder.com/forums/viewtopic.php?t=13140
Here you go,
While we're remarking:
vi src/zm_rtsp.cpp
and remark:
Looking like it's gonna pass, doing a make install now....
oops...
./configure --with-webdir=/var/www/zm --with-cgidir=/var/www/cgi-bin --with-webuser=www-data --with-webgroup=www-data
wow! it worked!
configuring more apache now....
vi src/zm_rtsp.cpp
and remark:
oops...
wow! it worked!
Did I screw up remarking it?newvisionantenna wrote:I figured that would be next, one sec. I'll brb.
Here you go,
