xUbuntu 1.24 Live CD
zoneminder_andre
Post by zoneminder_andre »
allanE wrote:newvisionantenna
Here you go, download this and move it to the correct folder. Delete the old or back it up, then run "tar xfvz filtersave.tgz" or something to that effect.
http://209.20.65.28/br549/filtersave.tgz
The file size is correct according to earlier suggestions.
Thanks ,This fixed the problem with the filter
Allan :D
Guys, can you help me out here.
I had the same issue with the filersave.php and replaced it with the above.
Saving the filter does not bring up the error anymore but it doesn't save either. So what can I do?
The purge filter is quite important ;-)
Andre
BitBass
Post by BitBass »
Ok, has the file changed? Am I losing my mind? I've tried "save as" and wget directly from the CLI on that file. Whatever I do the contents of the file are literally:
<br>
<b>Fatal error</b>:  Call to undefined function canEdit() in <b>/usr/local/apache/htdocs/zm/files/filtersave.php</b> on line <b>21</b><br>
The TGZ file is also offline, at least for me. What am I missing folks?
kalross
MYSQL Root Pass
Post by kalross »
What is the MYSQL root pass....I've updated to 1.24.2 (eventually) and now can't access database.
Cheers.
K
curtishall
Re: MYSQL Root Pass
Post by curtishall »
kalross wrote:What is the MYSQL root pass....I've updated to 1.24.2 (eventually) and now can't access database.
Cheers.
K
The mysql root password is located in /root in a text file.
Curtis Hall
Bluecherry
www.bluecherrydvr.com
store.bluecherry.net
znelbok
Post by znelbok »
Hi guys
Very new to this hence I am using a liveCD.
I installed this in a VM for testing, It loads alright, but the OS wants me to login and I don't know any user-names or passwords.
How do I move forward from here
Mick
dwarftosser
Post by dwarftosser »
Allan :D
Andre
Neither of these links seem to be active anymore. Is there somewhere where I can download the correct filtersave file for the live cd? Zoneminder is pretty much worthless without a working purge filter.
