64 bit
NedraE
64 bit
Post by NedraE »
I would like to use the "plain vanilla" install guide to do a 64-bit installation.
What changes would need to be made in configuration, etc. ??? :?:
I'd like to not use shmall and shmmax.
I would prefer to use the new memory management.
Nedra E
zoneminder
Site Admin
Post by zoneminder »
Add --enable-mmap=yes to the configure line. Make sure you have a tmpfs partition, usually /dev/shm, that is large enough. On most systems it will be without having to change anything.
Phil
