I am currently using the default zone settings.
What settings in particular should I start playing with to try to get it to not pick up light level changes?
zone settings to change to not pick up light level changes?
The "Overload Frame Ignore Count" parameter on the zone settings pages helps the motion detection ignore lighting changes a little bit. You can try setting it to the fps of of your monitor to tell it to ignore drastic pixel changes for 1 second and then keep raising the value until you get acceptable results. It won't eliminate all the false motion events based on lighting changes but it will reduce the number of them significantly.
Ok... I have my max fps set to 15 but then a 0 in the alarm max frame count. My recordings are usually at 29.xx fps.
So should I set it up 15 or 30 ?
timcraig wrote:The "Overload Frame Ignore Count" parameter on the zone settings pages helps the motion detection ignore lighting changes a little bit. You can try setting it to the fps of of your monitor to tell it to ignore drastic pixel changes for 1 second and then keep raising the value until you get acceptable results. It won't eliminate all the false motion events based on lighting changes but it will reduce the number of them significantly.
