is this Camera working with ZoneMinder ?
Linksys WVC54GCA
http://www.linksys.com/servlet/Satellit ... 1687048B01
greetz
big brother
Linksys WVC54GCA
Not sure anyone has tryed that paticular one.
http://www.google.com/search?hl=en&safe ... tnG=Search
I was able to configure the camera and make it work with Zone Minder.
As you can see I configured it for 10 fps, but ZM is reporting between 0.5 and 1.0 fps. When you load the image in the browser you can also tell that the camer is just very slow. It's on 54Mb wireless close the the router, so I should be able to get close to full speed. I think the camera is just too slow.
There also seems to be a lot of noise in the image, so adjusting the motion detection is tricky. Have not found a good setting yet that does not get false positives and at the same time captures motion when it happens.
I disabled authentication in the camera itself, as it is on my internal network. Not sure how you would pass credentials from ZM to the camera if you wanted to enable security on the camera.
I can't recommend the camera because of the speed of capture and the image quality.
Here are my settings:
if you check the forum it is littered with similar comments about linksys cameras
James Wilson
