i install in same system that i have .0.15 .. all fine.
i make a camera and i have a error.
Unknown column 'FrameSkip' in 'field list'
the camera is create anyway.
list of 0.16 bugs.
Re: list of 0.16 bugs.
well is i continue testing the camera dont work.
frame skip is not record..
but i will install it on a 0 system. to see if is mi install or is really zm.
cmae back in 10 minutes.
- zoneminder
- Site Admin
- Contact:
Hi Fernando,
I will be dealing with these kind of issues on the .16 thread in the General forum just so I don't have to keep checking different threads. Anyway, your problem is because the zmalter script for upgrade from .15 was missed out of the distribution and the FrameSkip field was missing from the schema as well. I have remade the package and reuploaded if you want to download it again.
Phil,
Phil,
