Hi I tried to search and find an answer but nothing helps so far..
so here my problem:
I have zm on a debian box runnin..a test with a usb webcam is succesfull..
i got a robocam 2 cam..the webtest is successfull..
on http://www.angelpage.de/7links-robocam.htm is written that the image can be grabbed through http://username:passwort@ip:port/cgi/jpg/image.cgi..
this works in a browser on http://user1:user1@192.168.0.1:10000/cgi/jpg/image.cgi
..but when i try to add this to zm there s only a black box shown and no picture.
i also tried without cambozola and different settings but no success so far..
configuration of the cam in zm:
General settings:
Sourcetype: Remote
Function: Monitor
Activated: YES
Source Settings:
Remote Host: user1:user1@192.168.0.1
Remoteport: 10000
Remotepath: /cgi/jpg/image.cgi
Colour: 24 Bit
width: 240
height: 320
any help would be nice..
Zoneminder Debian/ Robocam2
start reading the logfile first is the advice
the error was the shmax and shmin value was too low..after setting it up to 8gb everything works now..thanx for the tip
