ZM New setup Question (fps)
richnyla
Post by richnyla »
I'm still new to ZM, but I have a strange problem. When I view live video my FPS shows up as a large negative number. Here are the specs on the system.
Supermicro X7SBA motherboard
X3220 Quad core Xeon processer
8GB Ram
CentOS 5.3 x86_64
I have 17 cameras on the system 16 via PV-183, and 1 IP camera. I had interlacing issues with the cameras attached to the PV-183 untill I dropped the resolution to 320x240. I tested this out on a smaller system using the i386 load of CentOS and had no problems. I used the 64-bit load on the production system due to the ram. The link shows a sample of what I am talking about.
http://www.a1computer.com/image1.jpg
rsdvd
Post by rsdvd »
Hello
I am seeing the same problem, very large negative numbers for FPS and also large numbers for the Zoom.
Does any one have any ideas why ths woudl happen.
I am also using CentOS 5.3 x86_64.
richnyla
Post by richnyla »
If I review the messages log file it shows the correct fps, but I still get the large negative number, plus the large zoom number. Here is part of the log.
Apr 27 09:25:39 ghcrdvr zmc_dvideo0[7805]: INF [PL01: 821000 - Capturing at 2.50 fps]
Apr 27 09:28:07 ghcrdvr zma_m4[28132]: INF [PL01: 173000 - Processing at 2.50 fps]
Apr 27 09:30:00 ghcrdvr zma_m4[28132]: INF [PL01: 173281 - Closing event 24424, section end]
Apr 27 09:30:00 ghcrdvr zma_m4[28132]: INF [PL01: 173281 - Opening new event 24434, section start]
Apr 27 09:32:20 ghcrdvr zmc_dvideo0[7805]: INF [PL01: 822000 - Capturing at 2.49 fps]
Apr 27 09:34:47 ghcrdvr zma_m4[28132]: INF [PL01: 174000 - Processing at 2.50 fps]
Apr 27 09:39:00 ghcrdvr zmc_dvideo0[7805]: INF [PL01: 823000 - Capturing at 2.50 fps]
Apr 27 09:40:00 ghcrdvr zma_m4[28132]: INF [PL01: 174780 - Closing event 24434, section end]
Apr 27 09:40:00 ghcrdvr zma_m4[28132]: INF [PL01: 174780 - Opening new event 24457, section start]
Apr 27 09:41:28 ghcrdvr zma_m4[28132]: INF [PL01: 175000 - Processing at 2.49 fps]
Apr 27 09:45:41 ghcrdvr zmc_dvideo0[7805]: INF [PL01: 824000 - Capturing at 2.49 fps]
Apr 27 09:48:08 ghcrdvr zma_m4[28132]: INF [PL01: 176000 - Processing at 2.50 fps]
Anyone have any sudgestions?
