Unrecognised content type 'multipart/mixed'
cam_
Post by cam_ »
Hi all,
is there a patch for zm_remote_camera.cpp available to handle those non-conform mjpeg-streams provided by some cams build by Trendnet , Micronet and others? Perhaps a proxy to convert into standard stream? Found some little hints in this forum but could not figure out if it is really possible.
Thanks for any help!
MrEvoMan
Post by MrEvoMan »
I thought the latest idea was to upgrade the firmware of the Trendnet cameras, which resolves that problem...
I have a TrendNet IP410 and the mjpeg stream works just fine after flashing to its latest firmware.
cam_
Post by cam_ »
I own a "7Links Wireless MJPEG Network IP CAM" http://www.pearl.de/a-PX1066-1120.shtml?query=7links
Perhaps this is the same hardware as Trendnet TV-IP201W but I'm not sure if it is possible to flash the "7Links" into a "Trendnet". But I will do further research on this, many thanks for this suggestion!!!
Greetings
cam_o
Ryu
Post by Ryu »
I believe Micronet SP5520 is the same or similar hardware/firmware like the ones you mention. Same specs, same problems etc.
http://www.micronet.info/up_images/engl ... manual.pdf
Video stream is accessible via cameraIP/goform/video like you cameras.
Shall I risk installing a Trendnet patched firmware? or I will simply kill the camera?
Micronet confirmed to me that there is no firmware upgrade from them :/
