#!/bin/sh
# create-database.sh
# Script to create Database with zmconfig.txt
# Date 12 Oct 2004
cat < zmconfig.txt | while true
do
read ligne
if [ "$ligne" = "Name: ZM_DB_SERVER" ]
then
read ligne
Script_DB_Server=`echo $ligne | cut -f2 -d" "`
echo "Server Name : $Script_DB_Server"
fi
if [ "$ligne" = "Name: ZM_DB_NAME" ]
then
read ligne
Script_DB_Name=`echo $ligne | cut -f2 -d" "`
echo "Database Name : $Script_DB_Name"
echo
fi
if [ "$ligne" = "Name: ZM_DB_USERA" ]
then
read ligne
Script_DB_Usera=`echo $ligne | cut -f2 -d" "`
echo "Admin Name : $Script_DB_Usera"
fi
if [ "$ligne" = "Name: ZM_DB_PASSA" ]
then
read ligne
Script_DB_Passa=`echo $ligne | cut -f2 -d" "`
echo "Admin Passwd : $Script_DB_Passa"
echo
fi
if [ "$ligne" = "Name: ZM_DB_USERB" ]
then
read ligne
Script_DB_Userb=`echo $ligne | cut -f2 -d" "`
echo "User Passwd : $Script_DB_Userb"
fi
if [ "$ligne" = "Name: ZM_DB_PASSB" ]
then
read ligne
Script_DB_Passb=`echo $ligne | cut -f2 -d" "`
echo "User Passwd : $Script_DB_Passb"
echo
fi
if [ "$ligne" = "Name: ZM_WEB_P_REFRESH_IMAGE" ]
then
echo " Create Database ..."
cd db
mysql mysql<zmschema.sql
echo "GRANT SELECT,INSERT,UPDATE,DELETE ON $Script_DB_Name.* TO $Script_DB_Usera@$Script_DB_Server IDENTIFIED BY '$Script_DB_Passa' ; " | mysql
echo "GRANT SELECT ON $Script_DB_Name.* TO $Script_DB_Userb@$Script_DB_Server IDENTIFIED BY '$Script_DB_Passb' ; " | mysql
echo "FLUSH PRIVILEGES ; " | mysql
mysqladmin reload
break;
fi
done
[a@a]# sh create-database.sh
[a@a]# chmod +x create-database.sh
[a@a]# ./create-database.sh
