configure: error: zm requires openssl/md5.h - use ZM_SSL_LIB
cagnaluia
Post by cagnaluia »
I have a problem, compiling zoneminder.
I'm using a fresh debian stable 5.0 release.
but.. when I'm compiling I read this
and this is my configure string:
./configure --with-webdir=/var/www/zm --with-cgidir=/usr/lib/cgi-bin/ --with-webuser=www-data --with-webgroup=www-data ZM_SSL_LIB=openssl
cagnaluia
Post by cagnaluia »
ok, apt-get install
libssl-dev
gnutls-bin
cordel
Post by cordel »
Glad you got it sorted, self help is always the best :)
Either development packages for Openssl or gnutls would have solved it.
