Not sure what I broke but suddenly I can't control my PTZ :(
carlo1973
Post by carlo1973 »
Not sure what I broke but now I can't control the PTZ cam's on our network :(
Originally I had PTZ working for 3 cams in both WATCH and Montage view. Everything worked fine.
Sometime over the weekend the camera controls in the Montage page stoped working. I dont know what changed. I wasn't here. All I know is it worked friday and monday it wasn't working. No errors - just was defaulting back to the first camera in the list and not able to control them.
In the process of trying to fix this issue, I managed to fubar, bork, decafinate, and general overal kaplowied the controls within the WATCH portion. Now controls don't work period <man>
[/code]
I tried adjusting the settings in the PTZ controls and changed from Continuous to Relative and it changed from moveConup to MoveRelup but no difference. still not working.
the camera is a Panasonic PTZ camera. As I said it was working before.
my control script for the Panasonic PTZ camera is as follows:
package ZoneMinder::Control::PanasonicIP;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# Panasonic IP Control Protocol
use Time::HiRes qw( usleep );
sub new
    my $class = shift;
    my $id = shift;
    bless( $self, $class );
    srand( time() );
    return $self;
our $AUTOLOAD;
sub AUTOLOAD
    my $self = shift;
    my $name = $AUTOLOAD;
    $name =~ s/.*://;
    if ( exists($self->{$name}) )
        return( $self->{$name} );
sub open
    my $self = shift;
    $self->loadMonitor();
    use LWP::UserAgent;
    $self->{state} = 'open';
sub close
    my $self = shift;
    $self->{state} = 'closed';
sub printMsg
    my $self = shift;
    my $msg = shift;
    my $msg_len = length($msg);
sub sendCmd
    my $self = shift;
    my $cmd = shift;
    my $result = undef;
    printMsg( $cmd, "Tx" );
    if ( $res->is_success )
        $result = !undef;
    else
    return( $result );
sub cameraReset
    my $self = shift;
    Debug( "Camera Reset" );
    my $cmd = "nphRestart?PAGE=Restart&Restart=OK";
    $self->sendCmd( $cmd );
sub moveConUp
    my $self = shift;
    Debug( "Move Up" );
    my $cmd = "cgi-bin/camctrl?tilt=-1";
sub moveConDown
    my $self = shift;
    Debug( "Move Down" );
    my $cmd = "cgi-bin/camctrl?tilt=1";
sub moveConLeft
    my $self = shift;
    Debug( "Move Left" );
    my $cmd = "cgi-bin/camctrl?pan=-1";
sub moveConRight
    my $self = shift;
    Debug( "Move Right" );
    my $cmd = "cgi-bin/camctrl?pan=1";
sub moveMap
    my $self = shift;
    my $params = shift;
    my $xcoord = $self->getParam( $params, 'xcoord' );
    my $ycoord = $self->getParam( $params, 'ycoord' );
    Debug( "Move Map to $xcoord,$ycoord" );
    my $cmd = "cgi-bin/camctrl?nphControlCamera?Direction=Direct&NewPosition.x=$xcoord&NewPosition.y=$ycoord&Width=".$self->{Monitor}->{Width}."&Height=".$self->{Monitor}->{Height};
sub zoomConTele
    my $self = shift;
    my $params = shift;
    my $step = $self->getParam( $params, 'step' );
    Debug( "Zoom Tele" );
    my $cmd = "nphControlCamera?Direction=ZoomTele";
sub zoomConWide
    my $self = shift;
    my $params = shift;
    Debug( "Zoom Wide" );
    my $cmd = "nphControlCamera?Direction=ZoomWide";
sub focusConNear
    my $self = shift;
    my $params = shift;
    Debug( "Focus Near" );
    my $cmd = "nphControlCamera?Direction=FocusNear";
sub focusConFar
    my $self = shift;
    my $params = shift;
    Debug( "Focus Far" );
    my $cmd = "nphControlCamera?Direction=FocusFar";
sub focusAuto
    my $self = shift;
    Debug( "Focus Auto" );
    my $cmd = "nphControlCamera?Direction=FocusAuto";
sub focusMan
    my $self = shift;
    Debug( "Focus Manual" );
    my $cmd = "/axis-cgi/com/ptz.cgi?autofocus=off";
sub presetClear
    my $self = shift;
    my $params = shift;
    Debug( "Clear Preset $preset" );
    my $cmd = "cgi-bin/camctrl?preset=scan";
sub presetSet
    my $self = shift;
    my $params = shift;
    my $cmd = "nphPresetNameCheck?PresetName=$preset&Data=$preset";
sub presetGoto
    my $self = shift;
    my $params = shift;
    my $cmd = "cgi-bin/camctrl?preset=$preset";
sub presetHome
    my $self = shift;
    Debug( "Home Preset" );
1;
__END__
Now your probably wondering why I have the home preset set to scan. Well my office really wanted a "Tour" option that steps through each of the presets on its own - this happend to be programed already into the camera and I'm just making use of it.
Also the other thing to note - I only changed the code to reflect the camera's controls. These camera's use cgi-bin/camctrl? for the controls.
Hope I can get help to solve this.
cordel
Post by cordel »
Are you sure your in the right forum?
this looks like a script for an older version of ZM.
If you didn't change anything and it was working before I would check and be sure that there is not some old sockets laying about. Then up the debug and try moving the cam through the command line, you should get something back useful.
carlo1973
Post by carlo1973 »
cordel wrote:Are you sure your in the right forum?
I hope this is the right forum. I installed ZM 1.24.1 from source. I will try to kill those sockets. I did see quite a few laying there but wasn't sure if I should do anything with them or not. thanks for the tip I'll get back to you if it's still being weird lol
[edit]
For the PTZ controls in the WATCH view, got that working now. Turned out to be a permisions issue of all things. Got that fixed. However PTZ in Montage is still borked.
