Help Decoding Foscam Ip Camera FI8908W
ronluna
Post by ronluna »
I'm trying to get the commands out Foscam IP Camera FI8908W with NeWave Ip Camera Web Server
I'm using Wireshark to get the comunication packets but I'm getting a hard time trying to decode it...
so far this what wireshark has returned after panning the camera to the right
0000 52 54 00 12 35 02 08 00 27 7a 30 9f 08 00 45 00 RT..5... 'z0...E.
0010 00 40 bf 3e 40 00 80 06 6d 59 0a 00 02 0f c0 a8 .@.>@... mY......
0020 01 69 08 1f 00 50 ad 6e 23 80 33 12 3e 21 50 18 .i...P.n #.3.>!P.
0030 ff a3 dc b8 00 00 4d 4f 5f 4f 0e 00 00 00 00 00 ......MO _O......
0040 00 00 00 00 00 01 00 00 00 01 00 00 00 06 ........ ......
ogm
Show your URL for testing
Post by ogm »
Why don't you post your IP Camera's URL to the forum so the good people here could help.
I, for one would like to know about this PTZ Wireless Camera.
ronluna
Foscam.pm
Post by ronluna »
I was able to get some codes for Foscam IP FI8908W and based on the other pm's that zoneminder comes with this is the result
I'm not a perl guru but at least I got it to pan/tilt and center with Zoneminder 1.24.1
package ZoneMinder::Control::Foscam;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# Foscam IP Control Protocol
use Time::HiRes qw( usleep );
sub new
my $class = shift;
my $id = shift;
bless( $self, $class );
srand( time() );
return $self;
our $AUTOLOAD;
sub AUTOLOAD
my $self = shift;
my $name = $AUTOLOAD;
$name =~ s/.*://;
if ( exists($self->{$name}) )
return( $self->{$name} );
our $stop_command;
sub open
my $self = shift;
$self->loadMonitor();
use LWP::UserAgent;
$self->{state} = 'open';
sub close
my $self = shift;
$self->{state} = 'closed';
sub printMsg
my $self = shift;
my $msg = shift;
my $msg_len = length($msg);
sub sendCmd
my $self = shift;
my $cmd = shift;
my $result = undef;
printMsg( $cmd, "Tx" );
if ( $res->is_success )
$result = !undef;
else
return( $result );
sub reset
my $self = shift;
Debug( "Camera Reset" );
my $cmd = "reboot.cgi?user=admin&pwd=";
$self->sendCmd( $cmd );
sub moveConUp
my $self = shift;
$stop_command = "1";
Debug( "Move Up" );
my $cmd = "decoder_control.cgi?command=0&user=admin&pwd=";
sub moveConDown
my $self = shift;
$stop_command = "3";
Debug( "Move Down" );
my $cmd = "decoder_control.cgi?command=2&user=admin&pwd=";
sub moveConLeft
my $self = shift;
$stop_command = "5";
Debug( "Move Left" );
my $cmd = "decoder_control.cgi?command=4&user=admin&pwd=";
sub moveConRight
my $self = shift;
$stop_command = "7";
Debug( "Move Right" );
my $cmd = "decoder_control.cgi?command=6&user=admin&pwd=";
sub moveStop
my $self = shift;
Debug( "Move Stop" );
my $cmd = "decoder_control.cgi?user=admin&pwd=&command=$stop_command";
sub whiteConIn
my $self = shift;
my $params = shift;
my $step = $self->getParam( $params, 'step' );
Debug( "White In $step" );
my $cmd = "/camera_control.cgi?2=$step";
sub whiteConOut
my $self = shift;
my $params = shift;
Debug( "White Out $step" );
my $cmd = "/camera_control.cgi?2=-$step";
sub presetClear
my $self = shift;
my $params = shift;
Debug( "Clear Preset $preset" );
my $cmd = "nphPresetNameCheck?Data=$preset";
sub presetSet
my $self = shift;
my $params = shift;
my $cmd = "nphPresetNameCheck?PresetName=$preset&Data=$preset";
sub presetGoto
my $self = shift;
my $params = shift;
my $cmd = "nphControlCamera?Direction=Preset&PresetOperation=Move&Data=$preset";
sub presetHome
my $self = shift;
Debug( "Home Preset" );
my $cmd = "decoder_control.cgi?command=25&user=admin&pwd=";
1;
if someone want to help finishing this script for full control.... this are the commands:
snapshot.cgi
description To obtain the snapshot
Permission visitor
Syntax /snapshot.cgi[?user=&pwd=&next_url=]
Parameters user:username
pwd:password
next_url:the name of snapshot
Note 1 If not use the parameter “next_urlâ€
wankelrx8
Foscam FI8908W Source Path
Post by wankelrx8 »
I also have a Foscam FI8908W and would really appreciate any help getting it to work in Zoneminder. Can you tell me what path you used in the Sources tab, to grab the video stream? This is one question that I can't seem to find an answer to, no matter how hard I search.
scribble
Post by scribble »
I would also like to know if anyone has successfully grabbed the video stream from a foscam into zoneminder.
scribble
Post by scribble »
Something to add is i know zoneminder is successfully logging into the camera as viewing the camera's log lists the ZM IP address as successfully logging in as ADMIN every 20 seconds or so.
It must be a bit complicated finding the stream? i've tried several versions of /videostream.cgi and /videostream.cgi[?usr=&pwd=&resolution=] to no avail.
troyy0206
Post by troyy0206 »
scribble wrote:Something to add is i know zoneminder is successfully logging into the camera as viewing the camera's log lists the ZM IP address as successfully logging in as ADMIN every 20 seconds or so.
I have one of those "fake" Foscam cameras that people are talking about. It's the purple one with the model IPCAM02. I was having the same problem and I figured out for some reason my ZM install just isn't showing 640x480. Had the same issue with an Axis 210. I'm not sure why yet, i'm new to ZM so I gotta research it.
However, I set the image to 320x240 in the "Source" on the console and set it to the same on the web interface of the camera and it's working fine!
Now I just need to figure out why it's not working at 640x480.
the path I used was /video.cgi?user=admin&pwd={password}
skyking
Post by skyking »
When a camera that will do a higher resolution works at 320 x 240, but not higher it is often due to shared memory issues.
http://www.zoneminder.com/wiki/index.php/FAQ
dollarbrand
Post by dollarbrand »
I just got a new foscam from www.foscam.us and wanted to set it up using Zoneminder.
This is the grab URL for the image with a clean Foscam camera (i.e., username="admin" password="" [password is blank]:
http://69.201.171.212/videostream.cgi?user=admin&pwd=
"It is not because things are difficult that we do not dare; it is because we do not dare that they are difficult." - Seneca
user888
Post by user888 »
jawesker
Please Help me I can make PT work over Foscam
Post by jawesker »
Hi everyone..
I can'nt make work "pan and tilt" over my foscam
I did every think..
I check the Foscam.pl source again again again.... but nothing happends..
I compile the source code from ubuntu, centos with out results..
I made it by .deb package nothing happends..
I made it from live cd but nothing..
In the logs says:
log: /var/log/messages
Jun 2 06:19:04 jawesker-laptop zmcontrol[2180]: INF [Starting control server 1/FoscamFI8908W]
Jun 2 06:19:04 jawesker-laptop zmcontrol[2181]: INF [Control server 1/FoscamFI8908W starting at 10/06/02 06:19:04]
Jun 2 06:19:12 jawesker-laptop kernel: [ 2081.682296] hrtimer: interrupt took 3306052 ns
log: /var/log/syslog
Jun 2 06:21:52 jawesker-laptop zmcontrol[2284]: INF [Control server 1/FoscamFI8908W starting at 10/06/02 06:21:52]
Jun 2 06:22:02 jawesker-laptop zmcontrol[2283]: FAT [Can't connect: No such file or directory]
In the others logs such as zmwatch.log zmdpk.log zmdc.log zmaudit.log zmfilter.log I don't get any error or logs (I found those files in /temp is rare it has to be at /var/log/zm/)
I tried averything all ready, in the original Foscam software it works with out any trouble
Please Help me
Aguante Zoneminder
_________________
I want make my tesis with zoneminder and foscam
daveharris
Post by daveharris »
