I have zoneminder working on the plug. Still testing performance but it looks pretty good.
Some good soul (thanks good soul!) already compiled version ZM 1.23.3, so I did not have to do much except
apt-get install zoneminder
it fails a couple of times, but
apt-get -f install zoneminder
apt-get upgrade zoneminder
+ manual addition of zoneminder.conf file
did the trick.
If you are trying this and need help, post it here and I will try to assist.
Linux "Plug Computer" for $99 - many possibilities
If anyone want's a Plug for about half price let me know. I got it today, played with it for about 2 hours, had Zoneminder running, motion, and some other things. I decided to get brave and flash the 2.6.30 something kernel that the NSLU2 team is working on and since I was half asleep when I did it it's not booting. I don't have the time nor the interest now to mess with it. I know it can easily be recovered with the usb package on the marvel site, but I've got to many projects to work on.
Just PM me if you want it
I am looking at installing ZM on a QNAP TS-219 which is using the same Kirwood plateform.souverain wrote:I have zoneminder working on the plug. Still testing performance but it looks pretty good.
Could you lay down the details of how you got ZM working ?
I will first have to install lenny on Ts-219 (thanks to Martin Michlmayr work)
and then ...
I am afraid the package that one can apt-get is ZM 1.23 and not 1.24
Yes, all you can get through apt-get is 1.23.3.
However, I know you can cross compile the latest version of zm, but I have not done that.
All you have to do is:
(1) boot the plug and configure networking - I assume this is already done.
(2) % apt-get zoneminder.
When I did #2, I got a dpkg error on some related packages. All I did to resolve those errors was:
After you get that error, try apt-get -f install to force an install of the files that didn't get loaded because of the error. Then try apt-get upgrade again, apt-get -f install back and forth until only the package that has the error is left.
If you are getting a specific error, please post it, but otherwise the above steps will get your 1.23.3 working. Sorry I did not cross-compile 1.24. I read about it but our current application works fine with 1.23 features. I will compile 1.24 at some point in the future.
I'm interested in some of these options, especially the router option. Some of you might have seen my post a while back:
http://www.zoneminder.com/forums/viewtopic.php?t=12929
I'd like to get one of these going with perl Devices:Serial and play around.
MRD
