To remaster the ZMliveCD you begin by installing from the CD to a partition. I use a partition 2.5 GB in size. This is enough if you can use another partition for mklivecd temp files and the final iso file. If you want to keep everything together better start with 3.5GB.
After installation is complete, reboot into the new system.
There are some files in /home/user/bin that run mozilla-firefox displaying the help documents. They are run by Desktop files in .kde/Autostart. If you trace them out you will find a little shell game that shuffles the Desktop links from /home/user/Documents/scripts to .kde/Autostart in such a way that one file is displayed on the livecd and another is displayed after installation.
Anyway, open a konsole and run the command "bin/installer". Then press the "Cancel" button to close the livecd_installer window. Now all the Desktop entries will be shuffled back in preparation to build another CD.
The command "mklivecd new.iso" will now build a new livecd. (must be run as root, or use sudo ) "mklivecd --help" will display a message detailing all the command line switches. I have wrapped the command in a simple shell script in "/home/user/bin/mkzmcd" . You can just edit this file to reflect your path to temp files and the final iso. You must mount any partitons manually if used for temp and the final iso.
Now you can make any changes you want to the system. Then run "sudo bin/mkzmcd".
That's it. Really. Have fun.
