Error on file zm_funct.php
maikdema
Post by maikdema »
In version 1.23.3 (ubuntu) I've changed file zm_funct.php in order to make close brackets in filters to work properly:
I've changed line 1343:
  ...type=\"hidden\" \"name=filter[terms][$i][cbr]..."
to:
  ...type=\"hidden\" name=\"filter[terms][$i][cbr]..."
Look the double quote before the
name=
Double quotes should go after
name=
Don't know if is a bug only in tis version or if it's global, and don't know if it's solved in nexts releases.
See you.
Normando
Post by Normando »
Yes, but I have the bug on the line 1349 (1.23.3)
