IP9100a with Yoics firmware video shifing problem
ceraldi
Post by ceraldi »
I searched but could not find an answer so here goes.
I have a IP9100a loaded with the yoics firmware and 4 cams feeding it, every so often the video from one of the 4 (any of the 4) will "shift" down or up and leave a black bar on the image in the middle usually triggering an alarm in zone minder. here is a picture of what happens.
http://picasaweb.google.com/lh/photo/Uo ... directlink
Any Ideas? it NOT a problem with ZoneMinder as I see it happen on the ip9100a directly on its web interface and its not all that frequent either but just annoying.
Thanks for any help!
kingofkya
Post by kingofkya »
if posiable slow fps down
it happens because of the cheap chip (most likely copied in china)
mycal
Post by mycal »
I've seen this before major reasons are:
1) mixing PAL and NTSC cameras.
2) improper resolution set on 9100 (IE pal set to 320x240 or 640x480)
3) bad ground
4) bad power supply or camera
5) unhooked ports that are not turned off
