debian 5.0 - lenny
cagnaluia
debian 5.0 - lenny
Post by cagnaluia »
I tried to install zoneminder on debian 5.0, stable, LENNY.
But, without good results...
I would like install it by DEB, but dont exist any recent way to make this.
So I tried to install it followed the "manual" instruction based on source.
./configure
make install
but I have some knowledge problem to understand all of the steps, because all of the guide refear to old debian ustable distributions.
Somebody can help me with the correct instructions to install zoneminder, started from debian 5.0 Lenny ??
thanks
henriquejf
Post by henriquejf »
well, there *is* a deb file that permitts zm intalation via apt-get install zoneminder; but it is not the latest version 1.24.1; im not sure where to find it, but google a little more and you´ll find the .deb or the repository to add to the sources you need;
if you use debian **i think you may** follow the ubuntu guide with no big problems;
i suggest this one: (you´ll get the latest version this way)
http://www.zoneminder.com/wiki/index.ph ... ozola-0.7)
*** (copy and paste the whole link until the parenthesis close)
good luck !
edit: i think that will do it to the sources:
deb http://ftp.us.debian.org/debian etch main contrib non-free
deb http://ftp.uk.debian.org/debian etch main contrib non-free
# Debian Unofficial (contém o java, acrobat e outros pacotes "não livres")
deb http://ftp.debian-unofficial.org/debian sarge main contrib non-free restricted
# ZoneMinder
deb http://www.spic.net/zoneminder/debian/ ./
deb-src http://www.spic.net/zoneminder/debian/ ./
deb http://packages.dotdeb.org stable all
deb-src http://packages.dotdeb.org stable all
if it fails, you may find the .deb here
http://www.howtoforge.com/video_surveil ... der_ubuntu
Afterwards we download the .deb from the maintainer website:
wget ftp://www.northern-ridge.com.au/zoneminder/ubuntu/dapper/zoneminder_1.22.3-8_i386.deb
Next we install it with the following command:
sudo dpkg -i zoneminder_1.22.3-8_i386.deb
as i said, its an outdated version, so the ubuntu guide is a better bet;
also, the zm download page mentions:
If you are a Debian user, Zoneminder is available in the "unstable" distribution. Thanks to Peter Howard for his considerable efforts in achieving this.
Henrique Barbosa
Consultant
Juiz de Fora, MG - Brazil
cagnaluia
Post by cagnaluia »
ok, thanks
I'll search to follow this last one
Verbatim
Post by Verbatim »
I've just done a few installs on Lenny.
The following is laid out such that if you're SSH-ing into the machine remotely then you can cut and paste easily.
apt-get install dropbear
Add the following line to your sources file :
vi /etc/apt/sources.list (and add the following line)
Then you can perform the following :
apt-get update
You now need to add the link into Apache :
ln -s /etc/zm/apache.conf /etc/apache2/conf.d/zoneminder.conf
/etc/init.d/apache2 force-reload
You probably need to change a few things too once it's installed :
adduser www-data video
zmfix
/etc/init.d/zoneminder restart
And now for the shared memory (shget) error that you're likely to get :
vi /etc/sysctl.conf
# Memory Allocation for ZoneMinder #
kernel.shmall = 134217728
kernel.shmmax = 134217728
Some numbers for reference if you wish to increase the above :
67108864 = 64 Mbytes
134217728 = 128 Mbytes
268435456 = 256 Mbytes
536870912 = 512 Mbytes
Accurate timekeeping might be an idea :
apt-get install ntp
And if you want to move the directory somewhere else (/home for example):
cd /home
mkdir zoneminder
cd zoneminder
mkdir events images temp
cd ..
chmod 775 zoneminder -R
rm /var/cache/zoneminder -R
ln -s /home/zoneminder /var/cache/zoneminder
The ZM - Console is viewed remotely by (192.168.1.5 is my machine) :
UVC Streamer (if you're using it) is viewed at :
And MJPG Streamer (if you're using it) is viewed at :
To test a 'regular' camera (not remote/UVC) :
zmu -d /dev/video0 -q -v
And finally, a few example commands/logs to find out what's going on :
cat /var/log/syslog | tail
tail /var/log/syslog -n 100
lsusb
dmsg
When configuring ZoneMinder through the http panel, if you're in the UK then you might prefer the Day-Month-Year format (Source > Timestamp tab):
%N - %d/%m/%y %H:%M:%S
Debian 5.0 Lenny (no GUI) ('Standard' Installation Only, No Extras)
P4HT-3.0Ghz, 2GB RAM
Logitech QuickCam E3500 (remote)
jbaylina
Post by jbaylina »
I had to make a link to ffmpeg in order to create videos.
ln /usr/bin/ffmpeg /usr/local/bin/ffmpeg
papounet
1.23 or 1.24
Post by papounet »
this is more a question for verbatim,
when you get the package with apt-get, do you get the 1.23 or 1.24 version of ZM ?
I am interested in getting ZM 1.24 to work on Lenny
henriquejf
i suggest you check that by runnung
apt-cache show zoneminder
or the name of the correct package;
Henrique Barbosa
Consultant
