I've just installed zoneminder on Fedora core 2. (apache 2.0.49)
However when I go to the zm.php page it is blank. The source of the page is totally blank to.
Looking at the httpd error log I see:
[client 192.168.1.27] PHP Notice: import_request_variables(): No prefix specified - possible security hazard in /var/www/html/zm/zm.php on line 21
[client 192.168.1.27] PHP Fatal error: Call to undefined function: mysql_pconnect() in /var/www/html/zm/zm_db.php on line 21
Configure Command './configure' '--host=i386-redhat-linux' '--build=i386-redhat-linux' '--target=i386-redhat-linux-gnu' '--program-prefix=' '--prefix=/usr' '--exec-prefix=/usr' '--bindir=/usr/bin' '--sbindir=/usr/sbin' '--sysconfdir=/etc' '--datadir=/usr/share' '--includedir=/usr/include' '--libdir=/usr/lib' '--libexecdir=/usr/libexec' '--localstatedir=/var' '--sharedstatedir=/usr/com' '--mandir=/usr/share/man' '--infodir=/usr/share/info' '--cache-file=../config.cache' '--with-config-file-path=/etc' '--with-config-file-scan-dir=/etc/php.d' '--enable-force-cgi-redirect' '--disable-debug' '--enable-pic' '--disable-rpath' '--enable-inline-optimization' '--with-bz2' '--with-db4=/usr' '--with-curl' '--with-exec-dir=/usr/bin' '--with-freetype-dir=/usr' '--with-png-dir=/usr' '--with-gd' '--enable-gd-native-ttf' '--without-gdbm' '--with-gettext' '--with-ncurses' '--with-gmp' '--with-iconv' '--with-jpeg-dir=/usr' '--with-openssl' '--with-png' '--with-pspell' '--with-regex=system' '--with-xml' '--with-expat-dir=/usr' '--with-dom=shared,/usr' '--with-dom-xslt=/usr' '--with-dom-exslt=/usr' '--with-xmlrpc=shared' '--with-pcre-regex=/usr' '--with-zlib' '--with-layout=GNU' '--enable-bcmath' '--enable-exif' '--enable-ftp' '--enable-magic-quotes' '--enable-safe-mode' '--enable-sockets' '--enable-sysvsem' '--enable-sysvshm' '--enable-track-vars' '--enable-trans-sid' '--enable-yp' '--enable-wddx' '--with-pear=/usr/share/pear' '--with-imap=shared' '--with-imap-ssl' '--with-kerberos' '--with-ldap=shared' '--with-mysql=shared,/usr' '--with-pgsql=shared' '--with-snmp=shared,/usr' '--with-snmp=shared' '--enable-ucd-snmp-hack' '--with-unixODBC=shared,/usr' '--enable-memory-limit' '--enable-bcmath' '--enable-shmop' '--enable-calendar' '--enable-dbx' '--enable-dio' '--enable-mcal' '--enable-mbstring' '--enable-mbstr-enc-trans' '--enable-mbregex' '--with-apxs2=/usr/sbin/apxs'
Any ideas where I am going wrong?
Many thanks,
Mike
