Make error
craver84
Make error
Post by craver84 »
Hi, I've got an error when I start make:
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline  -frepo -g -O2 -MT zm_monitor.o -MD -MP -MF .deps/zm_monitor.Tpo -c -o zm_monitor.o zm_monitor.cpp
In file included from zm_rtsp.h:30,
                 from zm_remote_camera_rtsp.h:27,
                 from zm_monitor.cpp:33:
zm_sdp.h:9:2: error: #error "No location for rtsp.h found"
zm_sdp.h:24: error: ‘AVCodecContext’ was not declared in this scope
zm_sdp.h:24: error: ‘codec’ was not declared in this scope
zm_sdp.h:24: error: expected primary-expression before ‘int’
zm_sdp.h:24: error: initializer expression list treated as compound expression
zm_sdp.h:27: error: ‘AVCodecContext’ was not declared in this scope
zm_sdp.h:27: error: ‘codec’ was not declared in this scope
zm_sdp.h:31: error: ‘AVFormatContext’ was not declared in this scope
zm_sdp.h:31: error: ‘s1’ was not declared in this scope
zm_sdp.h:31: error: ‘AVStream’ was not declared in this scope
zm_sdp.h:31: error: ‘st’ was not declared in this scope
zm_sdp.h:31: error: ‘URLContext’ was not declared in this scope
zm_sdp.h:31: error: ‘rtpc’ was not declared in this scope
zm_sdp.h:31: error: expected primary-expression before ‘int’
zm_sdp.h:31: error: expected primary-expression before ‘*’ token
zm_sdp.h:31: error: ‘rtp_payload_data’ was not declared in this scope
zm_sdp.h:31: error: initializer expression list treated as compound expression
zm_sdp.h:32: error: ‘AVPacket’ has not been declared
zm_sdp.h:36: error: ‘URLContext’ was not declared in this scope
zm_sdp.h:36: error: ‘h’ was not declared in this scope
zm_sdp.h:37: error: ‘URLContext’ was not declared in this scope
zm_sdp.h:37: error: ‘h’ was not declared in this scope
zm_sdp.h:37: error: expected primary-expression before ‘const’
zm_sdp.h:37: error: initializer expression list treated as compound expression
zm_sdp.h:38: error: variable or field ‘rtp_get_file_handles’ declared void
zm_sdp.h:38: error: ‘URLContext’ was not declared in this scope
zm_sdp.h:38: error: ‘h’ was not declared in this scope
zm_sdp.h:38: error: expected primary-expression before ‘int’
zm_sdp.h:114: error: ‘AVPacket’ has not been declared
zm_sdp.h:122: error: use of enum ‘CodecType’ without previous declaration
zm_sdp.h:123: error: use of enum ‘CodecID’ without previous declaration
zm_sdp.h:126: error: ‘AVStream’ has not been declared
zm_sdp.h:138: error: ISO C++ forbids declaration of ‘AVFormatContext’ with no type
zm_sdp.h:138: error: expected ‘;’ before ‘*’ token
zm_sdp.h:139: error: ISO C++ forbids declaration of ‘AVStream’ with no type
zm_sdp.h:139: error: expected ‘;’ before ‘*’ token
zm_sdp.h:151: error: ISO C++ forbids declaration of ‘URLContext’ with no type
zm_sdp.h:151: error: expected ‘;’ before ‘*’ token
zm_sdp.h:183: error: variable or field ‘ff_rtp_send_data’ declared void
zm_sdp.h:183: error: ‘AVFormatContext’ was not declared in this scope
zm_sdp.h:183: error: ‘s1’ was not declared in this scope
zm_sdp.h:183: error: expected primary-expression before ‘const’
zm_sdp.h:183: error: expected primary-expression before ‘int’
zm_sdp.h:185: error: use of enum ‘CodecID’ without previous declaration
zm_sdp.h:185: error: use of enum ‘CodecType’ without previous declaration
zm_sdp.h:185: error: invalid type in declaration before ‘;’ token
zm_sdp.h:206: error: ISO C++ forbids declaration of ‘URLContext’ with no type
zm_sdp.h:206: error: expected ‘;’ before ‘*’ token
zm_sdp.h:217: error: use of enum ‘RTSPProtocol’ without previous declaration
zm_sdp.h:226: error: ‘AVFormatContext’ was not declared in this scope
zm_sdp.h:226: error: ‘s’ was not declared in this scope
zm_sdp.h:226: error: expected primary-expression before ‘const’
zm_sdp.h:226: error: initializer expression list treated as compound expression
In file included from zm_remote_camera_rtsp.h:27,
zm_rtsp.h:71: error: ISO C++ forbids declaration of ‘AVFormatContext’ with no type
zm_rtsp.h:71: error: expected ‘;’ before ‘*’ token
zm_rtsp.h:110: error: ISO C++ forbids declaration of ‘AVFormatContext’ with no type
zm_rtsp.h:110: error: expected ‘;’ before ‘*’ token
zm_rtsp.h:115: error: expected `;' before ‘bool’
In file included from zm_monitor.cpp:33:
zm_remote_camera_rtsp.h:51: error: ISO C++ forbids declaration of ‘AVFormatContext’ with no type
zm_remote_camera_rtsp.h:51: error: expected ‘;’ before ‘*’ token
zm_remote_camera_rtsp.h:52: error: ISO C++ forbids declaration of ‘AVCodec’ with no type
zm_remote_camera_rtsp.h:52: error: expected ‘;’ before ‘*’ token
zm_remote_camera_rtsp.h:53: error: ISO C++ forbids declaration of ‘AVCodecContext’ with no type
zm_remote_camera_rtsp.h:53: error: expected ‘;’ before ‘*’ token
zm_remote_camera_rtsp.h:54: error: ISO C++ forbids declaration of ‘AVFrame’ with no type
zm_remote_camera_rtsp.h:54: error: expected ‘;’ before ‘*’ token
make[2]: *** [zm_monitor.o] Error 1
make[2]: Leaving directory `/home/paolo/ZoneMinder-1.24.0/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/paolo/ZoneMinder-1.24.0'
make: *** [all] Error 2
paolo@VirtuaLinux:~/ZoneMinder-1.24.0$
how can I solve it?
thanks
zoneminder
Site Admin
Post by zoneminder »
What was your configure command and what was the output?
Phil
craver84
Post by craver84 »
Hi, I'm tring to install it on a dedicated PC with CentOS....
I'm following this guide:
http://www.zoneminder.com/wiki/index.php/CentOS
at first I had a problem installing ffmpeg. Looking around the forum I solved in this way:
svn checkout svn://svn.mplayerhq.hu/ffmpeg/trunk ffmpeg
cd ffmpeg/
./configure
make
make install
make install-libs
cd /root/
tar -zxvf ZoneMinder-1.24.0.tar.gz
cd ZoneMinder-1.24.0
make     <-------- errors
I think the error is due to ffmpeg...
I tried a different way to install ffmpeg like
yum install ffmpeg but it says:
Package ffmpeg - 0.4.9-0.9.29970530.el5.rf.i386 is already installed
the zm make error is:
zm_mpeg.cpp:325: error: 'img_convert' wan not declared in this scope
how can I solve it? Thanks!
richw
Post by richw »
It sound's like you have installed ffmpeg with yum at some point and you have complied a new version and installed it over the top.
I'd goto the ffmpeg directory you downloaded it to, do a "make uninstall" & "make uninstall-libs", do 'yum remove ffmpeg' and then look in the "tips and tricks" forum for the ffmpeg files and make sure it's been completely removed.
Once that is done, I'd reinstall ffmpeg you downloaded ('make install' &
'make install-libs') and then try to make ZM again.
zoneminder
Site Admin
Also for 1.24.x you need to have swscaler enabled in ffmpeg so you will need to add --enable-swscale --enable-gpl to the configure line for ffmpeg.
Phil
craver84
Post by craver84 »
I solved but I still have problems... I'm sorry but I'm a beginner with linux...
The web interface says that I need to install mootools, but I don't know how and where. (I haven't a /usr/share/zoneminder directory)
I think I should wait untill a stable version is released.
I also hope there will be an .rpm or .deb and the CentOS guide will be update (I followed it and I had the problems I wrote...)
Thanks to all the developers for their hard work!
zoneminder
Site Admin
This is a third party library but I will be doing a drop in the next day or two with it included in ZM so it will save one job at least.
Phil
monex
Post by monex »
I have a similar problem but I have disabled ffmpeg because I wanted to build a version without:
./configure --with-mysql=/usr/include/mysql --with-webdir=/srv/www/htdocs/zm --with-cgidir=/srv/www/cgi-bin --sysconfdir=/etc --bindir=/usr/bin --without-ffmpeg --without-lame --with-libarch=lib64 --with-webuser=wwwrun --with-webgroup=www --enable-crashtrace=yes --enable-debug=yes ZM_DB_HOST=localhost ZM_DB_NAME=zm ZM_DB_USER=... ZM_DB_PASS=...
I think for some users it is essential that ffmpeg is not mandatory requirement.
Syrinx
Post by Syrinx »
I'm having a problem similar to others in this thread. I'm installing ZM from code. Here's the error during the build step:
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/src/mysql/include -I/usr/lib/include -Wall -Wno-sign-compare -fno-inline -I/usr/lib/include  -frepo -O2 -I/usr/src/jpeg -MT zm_mpeg.o -MD -MP -MF .deps/zm_mpeg.Tpo -c -o zm_mpeg.o zm_mpeg.cpp
zm_mpeg.cpp: In member function ‘double VideoStream::EncodeFrame(uint8_t*, int, bool, unsigned int)’:
zm_mpeg.cpp:325: error: ‘img_convert’ was not declared in this scope
make[1]: *** [zm_mpeg.o] Error 1
make[1]: Leaving directory `/usr/src/ZoneMinder-1.24.1/src'
make: *** [install-recursive] Error 1
I'm guessing it may be a problem/conflict with ffmpeg. I've got Ubuntu's (Jaunty) bundled ffmpeg version installed. Synaptic Package Manager says this ffmpeg version is 3:0.svn20090303-1ubuntu6.
I think the subversion mentioned in the version string (svn) is ffmpeg's subversion server, which would make the ffmpeg version very recent (March 3, 2009).
My configure step indicated no problems.
Any ideas? Thanks.
Syrinx
Post by Syrinx »
I think I figured it out. If you look at the offending code, it has an ifdef:
#ifdef HAVE_LIBSWSCALE
        if ( !img_convert_ctx )
            img_convert_ctx = sws_getContext( c->width, c->height, pf, c->width, c->height, c->pix_fmt, SWS_BICUBIC, NULL, NULL, NULL );
                Fatal( "Unable to initialise image scaling context" );
        sws_scale( img_convert_ctx, tmp_opicture->data, tmp_opicture->linesize, 0, c->height, opicture->data, opicture->linesize );
#else // HAVE_LIBSWSCALE
                img_convert( (AVPicture *)opicture, c->pix_fmt, (AVPicture *)tmp_opicture, pf, c->width, c->height );
#endif // HAVE_LIBSWSCALE
I installed the libswscale package, and now it compiles/links/installs just fine.
However, it seems like a bug if the compile unconditionally fails when an ifdef condition is not met. Especially a silent condition. Might as well just remove the ifdef and loudly force everyone to install the libswscale package.
Should I file a bug or is there a good reason for the ifdef?
rrs
Remember to re-run "configure" after installing &q
Post by rrs »
In my case I installed the required components one-by-one as I found them missing due to compile errors during "make" attempts. But I had not gone back and re-run configure, to update the #define definitions in the C++ files so the new components will be used in the build process, hence the undefined symbol compile error. Once I re-ran "configure" the compile error was gone.
So, if you add or remove Linux components used by the build, remember to re-run "configure" before trying re-run "make". (starting with "make clean")
