Black bar in the middle of camera image
trunet
Post by trunet »
Hello everyone...
First off all, you develop a very good product, I installed them and it's amazing.
Second, sorry for my English, I know that it is terrible. I am Brazilian and here we speak portuguese.
My camera works fine, but appears a black bar in the middle of image, like the camera "rotate" the image in the screen. Like a TV with bad antenna.
A link of a image is here: http://www.gruporw.com.br/imagem.jpg
I think this is a v4l problem, but I don't find answer in google or other place. So, I came here to see if anyone has a solution to my problem.
Tkz in advance...
Wagner Sartori Junior
securiteaze
Post by securiteaze »
I had similar images in xawtv when my NTSC cameras were set for PAL, although the corruption was at the top instead of the bottom.
fernando
Post by fernando »
this is normal in bt878 cards.
check if the norm "signal" are ok? trie in 3 or 1.. most cameras are 3 or 1.
iam shure is that.
check the cable maybe to long coaxil rg59 can have a 150meters long with normal cameras. check the conectors.
Fernando
trunet
Post by trunet »
I take a look at the bttv documentation, and I don't find anything about norm setting. How I supposed to do that?
tkz for the help
trunet
Post by trunet »
I am very, VERY stupid. I found this configuration at the zoneminder device config, and everything works as expected.
Tkz for everyone who helps me!
victor_diago
Post by victor_diago »
Nice to know you are from brazil,
Me too, where are you from ?
Victor Diago
trunet
Post by trunet »
I am from Santos, I work in São Paulo(Interlagos) and the zoneminder is to control the turns of the employees online. The business is 24/7 and we need to see what they do at night.
my mail is wsartoriATuol.com.br
my msn is the same
If you want to mailme or msn-me to trade some ideas, I apreciate that.
