I am not a LINUX pro. I understand very little but desire to make progress.
I have this Comart card that has been sitting around unused and wanted to try ZoneMinder.
I have a working install of Fedora
KDE 3.5.10-1.fc8 Fedora
Linux Kernel 2.6.26.8-57.fc8
I have installed MySQL, Apache, ffmpeg, and everything else I saw that was required.
I think my main issue is no ability to login to mysql?
The error below is generated from the services applet when starting zoneminder.
I know I will have issues to deal with on this HiCap25 card but for now I need to get past these other items. Then I might try a web or IP cam.
Thanks Bert
zoneminder failed. The error was: DBI connect('database=zm;host=localhost','zmuser',...) failed: Access denied for user 'zmuser'@'localhost' (using password: YES) at /usr/lib/perl5/vendor_perl/5.8.8/ZoneMinder/Config.pm line 89
Can't call method "prepare_cached" on an undefined value at /usr/lib/perl5/vendor_perl/5.8.8/ZoneMinder/Config.pm line 91.
BEGIN failed--compilation aborted at /usr/lib/perl5/vendor_perl/5.8.8/ZoneMinder/Config.pm line 100.
Compilation failed in require at /usr/lib/perl5/vendor_perl/5.8.8/ZoneMinder.pm line 33.
BEGIN failed--compilation aborted at /usr/lib/perl5/vendor_perl/5.8.8/ZoneMinder.pm line 33.
Compilation failed in require at /usr/bin/zmupdate.pl line 48.
BEGIN failed--compilation aborted at /usr/bin/zmupdate.pl line 48.
