Streaming to an Xbox?
Jiberjaber
Post by Jiberjaber »
I have been trying without much success to stream video from ZM to my Xbox(s) to use them as convientiant viewers around the house...
They're all running XBMC (M Player) but I dont think I have the syntax of the playlist entry correct...
I have been creating .stm files (based in what I found in teh XBTV files) which are detected as playlists on XBMC. In there I have been putting an URL to the ZM stream,
http://192.168.1.5/cgi-bin/zms?Zode=jpe ... &maxfps=25
Looks like XBMC prefers .asf files, any way to stream them in ZM (ffmpeg or similar) ?
Anyone else tried this ?
Regards,
Jason
zoneminder
Site Admin
Post by zoneminder »
If you have ffmpeg libraries installed you can stream in asf mode, though the normal Window Media Player viewer does start to lag fairly quickly.
Did you mean 'Zode' by the way? If so then it should be 'mode' obviously. To stream asfs change the mode to 'mpeg' and add a 'format=asf' url parm.
Phil
Jiberjaber
Smashing, thanks for that will give it a try tomorrow... yup I think I meant Mode ;) :)
Regards,
Jason
mlrtime3
Post by mlrtime3 »
You ever get this working? Streaming to xbmc?
I'd like to try this as well.
mlrtime3
Post by mlrtime3 »
Just read this thread:
http://www.zoneminder.com/forums/viewtopic.php?t=3780
If we could get a python script to simply serve this mplayer url then we could get a xbmc plugin for zoneminder.
I know this is possible but I've never written a python script before.
This would also allow a cheap zoneminder client viewer for users.
sandara
Post by sandara »
Can you recommend a good video player to replace Windows media player?
Needs to be free, and as good as Media player. Media Player is not playing all of my downloaded files, I’m running XP and this is for downloaded files, not DVD’s movies.
________________
keyword research ~ keyword tool ~ keyword tracking ~ affiliate elite
kingofkya
Post by kingofkya »
for me its vlc
plays everything (even real player files as of last release
Videolan.org
newvisionantenna
Post by newvisionantenna »
The days of Xbox... Just install Zoneminder on a 2.6 Kernel Xebian install. I probably still have the precompiled Kernel along with 5 Xbox's in the cabinet that need worked on.
Heck, i've had Ubuntu running on the 360, you talk about the biggest pain to downgrade and get ahold of KK and the SDA disk. Was fun for about a week and then it got piled up with the rest of my projects. This was before I messed with Zoneminder, would have been cool to see it up and running if it would work with powerpc or whatever it is.
