Oh bleep...yeah, something seems wrong all right. Any idea what to do about it?
[Tue Jun 09 13:33:04 2009] [notice] Apache/2.2.9 (Ubuntu) PHP/5.2.6-2ubuntu4.2 with Suhosin-Patch configured -- resuming normal operations
df: `/media/disk/events': No such file or directory
df: no file systems processed
[Tue Jun 09 13:34:40 2009] [error] [client 127.0.0.1] MPEG streaming is disabled., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 13:34:40 2009] [error] [client 127.0.0.1] You should configure with the --with-ffmpeg option and rebuild to use this functionality., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 13:34:44 2009] [error] [client 127.0.0.1] socket_sendto( /tmp/zms-178970s.sock ) failed: No such file or directory, referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 13:34:44 2009] [error] [client 127.0.0.1] array (\n 0 => \n array (\n 'file' => '/var/www/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-178970s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 13:35:09 2009] [error] [client 127.0.0.1] MPEG streaming is disabled., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 13:35:09 2009] [error] [client 127.0.0.1] You should configure with the --with-ffmpeg option and rebuild to use this functionality., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 13:36:07 2009] [error] [client 127.0.0.1] MPEG streaming is disabled., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 13:36:07 2009] [error] [client 127.0.0.1] You should configure with the --with-ffmpeg option and rebuild to use this functionality., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 13:43:31 2009] [error] [client 127.0.0.1] MPEG streaming is disabled., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 13:43:31 2009] [error] [client 127.0.0.1] You should configure with the --with-ffmpeg option and rebuild to use this functionality., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 13:55:30 2009] [error] [client 127.0.0.1] socket_sendto( /tmp/zms-233657s.sock ) failed: No such file or directory, referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 13:55:30 2009] [error] [client 127.0.0.1] array (\n 0 => \n array (\n 'file' => '/var/www/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-233657s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 13:57:39 2009] [error] [client 127.0.0.1] socket_sendto( /tmp/zms-872683s.sock ) failed: No such file or directory, referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 13:57:39 2009] [error] [client 127.0.0.1] array (\n 0 => \n array (\n 'file' => '/var/www/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-872683s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 13:58:25 2009] [notice] caught SIGTERM, shutting down
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php5/20060613+lfs/ffmpeg.so' - /usr/lib/php5/20060613+lfs/ffmpeg.so: cannot open shared object file: No such file or directory in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php5/20060613+lfs/gd.so' - /usr/lib/php5/20060613+lfs/gd.so: cannot open shared object file: No such file or directory in Unknown on line 0
[Tue Jun 09 14:06:13 2009] [notice] Apache/2.2.9 (Ubuntu) PHP/5.2.6-2ubuntu4.2 with Suhosin-Patch configured -- resuming normal operations
[Tue Jun 09 14:11:30 2009] [error] [client 127.0.0.1] MPEG streaming is disabled., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:11:30 2009] [error] [client 127.0.0.1] You should configure with the --with-ffmpeg option and rebuild to use this functionality., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:11:34 2009] [error] [client 127.0.0.1] socket_sendto( /tmp/zms-852732s.sock ) failed: No such file or directory, referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:11:34 2009] [error] [client 127.0.0.1] array (\n 0 => \n array (\n 'file' => '/var/www/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-852732s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:39:00 2009] [error] [client 127.0.0.1] MPEG streaming is disabled., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:39:00 2009] [error] [client 127.0.0.1] You should configure with the --with-ffmpeg option and rebuild to use this functionality., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:39:31 2009] [error] [client 127.0.0.1] MPEG streaming is disabled., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:39:31 2009] [error] [client 127.0.0.1] You should configure with the --with-ffmpeg option and rebuild to use this functionality., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:39:55 2009] [error] [client 127.0.0.1] MPEG streaming is disabled., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:39:55 2009] [error] [client 127.0.0.1] You should configure with the --with-ffmpeg option and rebuild to use this functionality., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:42:15 2009] [error] [client 127.0.0.1] MPEG streaming is disabled., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:42:15 2009] [error] [client 127.0.0.1] You should configure with the --with-ffmpeg option and rebuild to use this functionality., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:42:38 2009] [error] [client 127.0.0.1] MPEG streaming is disabled., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:42:38 2009] [error] [client 127.0.0.1] You should configure with the --with-ffmpeg option and rebuild to use this functionality., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:42:42 2009] [error] [client 127.0.0.1] socket_sendto( /tmp/zms-888667s.sock ) failed: No such file or directory, referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:42:42 2009] [error] [client 127.0.0.1] array (\n 0 => \n array (\n 'file' => '/var/www/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-888667s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:50:57 2009] [error] [client 127.0.0.1] MPEG streaming is disabled., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:50:57 2009] [error] [client 127.0.0.1] You should configure with the --with-ffmpeg option and rebuild to use this functionality., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:51:01 2009] [error] [client 127.0.0.1] socket_sendto( /tmp/zms-945654s.sock ) failed: No such file or directory, referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:51:01 2009] [error] [client 127.0.0.1] array (\n 0 => \n array (\n 'file' => '/var/www/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-945654s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:59:44 2009] [error] [client 127.0.0.1] MPEG streaming is disabled., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 14:59:44 2009] [error] [client 127.0.0.1] You should configure with the --with-ffmpeg option and rebuild to use this functionality., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 15:03:25 2009] [error] [client 127.0.0.1] MPEG streaming is disabled., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 15:03:25 2009] [error] [client 127.0.0.1] You should configure with the --with-ffmpeg option and rebuild to use this functionality., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 15:04:35 2009] [error] [client 127.0.0.1] MPEG streaming is disabled., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 15:04:35 2009] [error] [client 127.0.0.1] You should configure with the --with-ffmpeg option and rebuild to use this functionality., referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 15:04:45 2009] [error] [client 127.0.0.1] socket_sendto( /tmp/zms-418991s.sock ) failed: No such file or directory, referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 15:04:45 2009] [error] [client 127.0.0.1] array (\n 0 => \n array (\n 'file' => '/var/www/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-418991s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 15:04:58 2009] [error] [client 127.0.0.1] socket_sendto( /tmp/zms-418991s.sock ) failed: No such file or directory, referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 15:04:58 2009] [error] [client 127.0.0.1] array (\n 0 => \n array (\n 'file' => '/var/www/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-418991s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://localhost/index.php?view=watch&mid=2
[Tue Jun 09 16:02:14 2009] [notice] caught SIGTERM, shutting down
[Tue Jun 09 16:05:26 2009] [notice] Apache/2.2.9 (Ubuntu) PHP/5.2.6-2ubuntu4.2 with Suhosin-Patch configured -- resuming normal operations
Looks like *something* went wrong while compiling!? I had followed the instructions at:
