Hello Is they any setting i can adjust on zoneminder to get delay down it seem to be people are out of the shot before it record they like 10 second delay
the system is run one camera on p4 2.80 with gig ram
run zoneminder on ubunto
Andy
camera are run in grey monitor also only 320 res
camera are pasonic they can 480 by 500 i think if need more if please let me know Any help wound be greatly appaitctede also shound be possable to run camera in color and corrected res on this box the card am run is gernic bt card 4 port drv winch my understand does 30 frame x 4 chanells?
ideo Capabilities
Name: BT878 video ( *** UNKNOWN/GENER
Type: 47
Can capture
Can tune
Does teletext
Overlay onto frame buffer
Can clip
Video Channels: 4
Audio Channels: 0
Maximum Width: 768
Maximum Height: 480
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 300
Height: 300
Picture Attributes
Palette: 1 - Linear greyscale
Colour Depth: 8
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 1
Channel has a tuner
Type: 1 - TV
Format: 1 - NTSC
Channel 1 Attributes
Channel: 1
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
Channel 2 Attributes
Channel: 2
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
Channel 3 Attributes
Channel: 3
Flags: 0
Type: 2 - Camera
Format: 1 - NTSC
Delay Before Recording Events
Thank for Quick Reply i also up res to higher
I have for setting
Image Buffer Size (frames) 40
Warmup Frames 25
Pre Event Image Count 10
Post Event Image Count 10
Stream Replay Image Buffer 1000
Alarm Frame Count 1
My cam res is = 760 x 480 ? will that cause delay am sure shound little no?
i only see imagine buffer size? or is title something diffent am look under camera setings page ?
I have for setting
Warmup Frames 25
Alarm Frame Count 1
