TVIP400w No Picture with /MJPEG.CGI but works with /IMAGE.JP
seank
Post by seank »
I have spent a few hours looking for A's and playing with settings but still no picture with 1.23.3.
My TVIP400w works fine on 1.24, except that the PTZ driver is for 1.23. So I have installed 1.23x with apt-get install zoneminder on ubuntu 8.1 which gives me 1.23.3.
I can get a picture at .86 frames per second if I use /IMAGE.JPG as the source path. If I use /MJPEG.CGI like I did on 1.24 I dont get a picture. My apache logs are clean. But I get this error in zmdebug with MJPEG.CGI
remote_camera.cpp/880 [Unable to extract subheader from stream, retrying]
Any input would be appriciated
thx
seank
Post by seank »
ZM_NETCAM_REGEXPS set to 0 and it is now working. Hopefully this post helps someone else :)
Normando
Post by Normando »
seank wrote:ZM_NETCAM_REGEXPS set to 0 and it is now working. Hopefully this post helps someone else :)
THANK YOU VERY MUCH!!!!!
syndacate
Post by syndacate »
Where can I find the "ZM_NETCAM_REGEXPS" option?? I have no idea, and iI'm totally new to ZM...thank you
Normando
Post by Normando »
Go to "Options" -> "Network" and uncheck "ZM_NETCAM_REGEXPS"
syndacate
Post by syndacate »
Thnak you....i tried it but it didn't work! I haven't that camera but another one similar with a cgi path...! I opened another thread about that...if someone could help me......
