Record as long as there is motion?
quietas
Post by quietas »
What am I doing wrong?
I want to record as long as there is any motion occurring on the camera. I seem to primarily get these 3-4 second recordings wher you can see someone walk into view, then walk halfway across, then end of recording.
What do I need to look for to adjust this?
Normando
Post by Normando »
Try disabling "BLEND_ALARMED_IMAGES" at options.
quietas
Post by quietas »
THanks, I'll give that a try.
quietas
Post by quietas »
Unfortunately not it is not recording anything.
It seemed to have been stuck with a 130000+ second event, not alarmed, but massively long.
kylejohnson
Post by kylejohnson »
Try increasing the post event buffer size by various amounts.
From the wiki:
A value of 10 for both of these will get you started but if you get a lot of short events and would prefer them to run together to form fewer longer ones then increase the Post Event buffer size.
